D510MO
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 13:59 #12617 by schmidtmotorworks
Replied by schmidtmotorworks on topic Re:D510MO
Does yours actually boot from the CD?
If you do boot from the CD, do any of the Admin tools see the HDD and let you format/partition/mount/whatever it?
Yes I can get it to boot from the CD but when I do, it can't find the hard drive.
The main pattern I see is that if I disconnect the hard rive and reconnect it, soemtimes the boot will go quickly and will respond to F2 in about 2 seconds.
If I don't change anything and boot it again, it will take a few minutes to respond to F2 and it won't find the hard drive.
Possibilites, maybe the power supply isn't working properly and not letting the HDD turn off properly?
Maybe the hard rive is faulty?
Maybe the motherboard is faulty?
Not sure what to try next.
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 16:38 #12618 by schmidtmotorworks
I brought the HDD to Frys on the way to work, and the tested it on a bench computer, it worked fine.
Unless I'm missing something this narrows it down to the mother board.
I think I passed 30 days so I will probably have to buy another one.
19 Aug 2011 16:50 #12619 by TarHeelTom
Replied by TarHeelTom on topic Re:D510MO
Have you a way to run a memory check?
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 17:06 #12620 by schmidtmotorworks
There was some kind of memory check when I was starting ubuntu from the CD, I let it run for about 15 minutes and didn't see any problems so I stopped the test, it looked like it could run for a long time based on the % indicator.
I was able to run ubuntu and EMC2 from the CD so I assume that the memory must be working OK.
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
19 Aug 2011 17:15 #12621 by BigJohnT
Replied by BigJohnT on topic Re:D510MO
Does it "see" the HD in the bios setting screen?
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 18:14 #12624 by schmidtmotorworks
That is the strange thing, it does see the HDD the first time it is connected and booted and I go to the BIOS page, but if I boot it again without touching anything else and go to the BIOS page the HDD is not shown. It says something like "no hard disk drive".
  • BigJohnT
  • Administrator
  • Administrator
19 Aug 2011 18:34 #12625 by BigJohnT
What if you plug the HD into the other SATA port does it still disappear on you? Just trying to do some hillbilly diagnostics...
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 18:58 #12626 by schmidtmotorworks
Tried that, too, same result, also tried switching cables, reveresed them end to end, same results.
  • BigJohnT
  • Administrator
  • Administrator
19 Aug 2011 19:07 #12627 by BigJohnT
That does sorta sound like the motherboard to me then... but you don't have another HD to eliminate that possibility so could be either at this point.
Is the CD drive found every time no matter what port you plug it into?
  • schmidtmotorworks
  • Elite Member
  • Elite Member
19 Aug 2011 20:19 #12628 by schmidtmotorworks
Thanks for suffering through this with me.
I don't have another SATA drive, this is my first SATA computer. Might be worth buying one to troubleshoot with.
I think the CD is found everytime, about 90% sure of that.
Looks like the next move is another mother board, I don't have a good feeling about this but what else can I try?
Time to create page: 0.207 seconds
