D510MO
- Thank you received: 1462
23 Dec 2012 11:32 - 23 Dec 2012 11:34 #27975
Replied by Todd Zuercher on topic D510MO
My Intel D2700MUD will just barely do a 400000 servo thread. But I think i backed it off to 500000 for reliability.
Last edit: 23 Dec 2012 11:34 by Todd Zuercher.
- JZHA1985
- Thank you received: 3
10 Feb 2013 10:38 - 10 Feb 2013 10:53 #29835
by JZHA1985
Replied by JZHA1985 on topic D510MO
Mine for some reason my D510 won't work.
I found the parallel port address using the terminal,
and used it but got a pipeline error where I can't jog within stepconfig or launch LinuxCNC. Is there a simple fix for this?
The new system has under 10,000 latency, a 60GB Intel SSD, and 1 GB of ram. I'm rather stumped.
Last edit: 10 Feb 2013 10:53 by JZHA1985.
- JZHA1985
10 Feb 2013 11:36 #29837
by JZHA1985
Here are the error messages.
One for when LinuxCNC fails to start.
And one for Stepconf when ran from terminal and when I press the jog button.
...After jogging within(trying to)
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.1
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/my-mill/my-mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=1528
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hal_parport.ko': -1 Device or resource busy
my-mill.hal:7: exit value: 1
my-mill.hal:7: insmod failed, returned -1
See the output of 'dmesg' for more information.
1528
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 87.135014] I-pipe: Domain RTAI registered.
[ 87.135030] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 87.135036] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 87.135129] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 87.135134] PIPELINE layers:
[ 87.135140] f9ab4e20 9ac15d93 RTAI 200
[ 87.135146] c085cb20 0 Linux 100
[ 87.184989] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 87.185441] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 87.185455] RTAI[sched]: hard timer type/freq = APIC/10391730(Hz); default timing: periodic; linear timed lists.
[ 87.185463] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1662781000 hz.
[ 87.185469] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 87.185616] RTAI[usi]: enabled.
[ 87.274096] RTAI[math]: loaded.
[ 87.392332] config string '0378-037a out '
[ 87.392354] PARPORT: ERROR: request_region(0xffff) failed
[ 88.154122] RTAI[math]: unloaded.
[ 88.208405] SCHED releases registered named ALIEN RTGLBH
[ 88.236515] RTAI[malloc]: unloaded.
[ 88.336033] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 88.340483] I-pipe: Domain RTAI unregistered.
[ 88.340605] RTAI[hal]: unmounted.
<stdin>:5: exit value: 1
<stdin>:5: insmod failed, returned -1
File "/usr/bin/stepconf", line 2024, in update_axis_params
halrun.flush()
IOError: [Errno 32] Broken pipe
- Thank you received: 5187
10 Feb 2013 12:43 #29839
Replied by PCW on topic D510MO
shouldn't the hal_parport config line just be:
loadrt hal_parport cfg="0x378 out "
- JZHA1985
10 Feb 2013 12:55 #29841
by JZHA1985
I tried that and I didn't get the errors, however, I wasn't getting an output to my drivers. I'm using the same settings as my other computer that's right below the bare motherboard I'm working with. I'm rather stumped,
there should be some sort of signal coming out of the parallel port.
- JZHA1985
10 Feb 2013 14:00 - 10 Feb 2013 14:03 #29842
by JZHA1985
Okay now it works minus the Y axis.
Uploaded with ImageShack.us
I remember reading somewhere within this thread there were reversed pins?
It works with the 8 year old P4, which I'll move into the house to work alongside with the new machine until i get this sorted out.
I thought this was going to be easy, install LinuxCNC, and go. I've used it for a year, and until now have found it effortless to use. But several hours and it's been rather fruitless :/
(Ps the Xyltoex board and steppers do cause wifi interference, I had them on, and it killed the streaming of my sister's phone)
Last edit: 10 Feb 2013 14:03 by JZHA1985.
- ArcEye
- Thank you received: 758
10 Feb 2013 18:17 #29852
by ArcEye
Would be a good idea to read pages 5 and 6 at least
The header apparently has 26 pins (and a parport D connector has 25), seems that the wire picked out in red you would expect to be No1 actually sits on the No 26 pin.
Replied by ArcEye on topic D510MO
- JZHA1985
11 Feb 2013 02:11 - 11 Feb 2013 03:13 #29868
by JZHA1985
Pins 4 and 5 that supposedly go to the Y axis are causing me issues.
I'm not sure what to do since they should be correctly pinned out.
STEP X PD0 2
DIR X PD1 3
STEP Y PD2 4
DIR Y PD3 5
STEP Z PD4 6
DIR Z PD5 7
Maybe the easiest thing to do is simply purchase a PCI card for a parallel port?
In theory it should work right now, but for some reason it is not.
STEP X PD0 2
DIR X PD1 3
STEP Y PD2 4
DIR Y PD3 5
STEP Z PD4 6
DIR Z PD5 7
Last edit: 11 Feb 2013 03:13 by JZHA1985.
- JZHA1985
11 Feb 2013 04:22 #29873
by JZHA1985
I think the cable is bad, or a few of the motherboard's header pins are dead.
Therefore I'm going to solder in the A axis as the Y axis, and see if that works.
Time to create page: 0.129 seconds
