D510MO
- BigJohnT
- Thank you received: 1175
- PKM
- Thank you received: 3
- BigJohnT
- Thank you received: 4966
Been running the latency test for 8 hours now and it is just a tad bit below 7k ns. So about 3k better than doing nothing at all on the D510MO.
Try it with a web-cam tab (and a web cam). Mine really messes up the latency, which is a real shame.
- BigJohnT
- 1:1
I have this motherboard here right now out of the box - going to be using some Mesa cards with it and the idea is a linux only install on a 32Gb SSD...
How did you install Ubuntu/EMC on it without a CD drive ? I've heard it can be done via a USB stick, but a google search is a bit messy on this topic - any links or instructions (for an inept mac user) for a known solution would be great
- BigJohnT
- 1:1
- schmidtmotorworks
- Thank you received: 6
Reading the other thread in the CNC Machines section about the MV35/40 retrofit, I saw there was some grouping of Mesa cards that would work for one slot but there were some conditions about base threading that I don't understand yet.
I am planing a retrofit for an Mori Seiki MVJR servo driven CNC Mill. Presently 3 axis with tool changer but it has servos for 5 axis, not sure if I will ever use them or not.
Thanks for any advice.
- Thank you received: 5187
