EMC2 running on Raspberry Pi?
13 years 11 months ago #26897 by mungkie
awallin wrote:
mhaberler wrote: there is something wrong with either the branch, or the autogen/configure step
could you pastebin the top few lines of 'git log', as well as the src/configure?
When doing the debian install I installed "debian-desktop" also. This may have been a mistake since it is quite slow and not really suitable for web-kiosk or similar use. Does anyone know what lightweight X/desktop envirionment people use on the Pi?
It seems my Pi now has some problems because after the X login screen it seems the window-manager does not start. I just get a screen with the debian background-image and the mouse works - but nothing else. The machine is alive as there are text-consoles with ctrl-alt-F1 etc.
So I will probably have to do a re-install and report back after that...
Anyway my first impression of the Pi is that it is disappointingly slow for desktop use with debian-desktop :( Makes me want to use ITX/Atom boards for my projects instead.
Try using the standard X installation that comes with the raspbian distribution it is about 5 times faster for X performance than the debian-desktop package!
Download from downloads.raspberrypi.org/images/raspbia...-wheezy-raspbian.zip
You can write it to SD card using win32diskimager on ms windows or dd if you are in linux
Also I would suggest not using the rpi if you can afford a decent ITX/Atom board, this is only a hack/experimental development at present and does not work correctly.
I compiled the rtos preview for RT_PREEMPT this morning and found that:
1) Will not compile for kernel threads option of ./configure
2) latency-test totally locks up the system when run for user threads rt-preempt compile
3) axis seem to run but shows missed deadlines and page faults.
So my question is what exactly is a realtime page fault and how can it be fixed?
I think rpi will become a usable system if there are enough talented people willing to work on fixing problems and finding work arounds, I am not sure if I have enough talent to fix it myself.
Unfortunately I also feel linuxcnc has a bias to x86 arch (In fact I get the feeling the project goals state it will only support x86), also the idea of creating lower cost hardware does not leave chance for large profits so does not encourage anyone to work on this as something supporting a business, and possibly pisses a lot of people off as it would put them out of business.
I would love it if there was an x86 based board that was available off the shelf for $35 and would run linuxcnc, and I would dump the rpi if there was, but I doubt this will happen in the forseeable future.
I am going to have a bit of a hack this weekend, but looking at my previous code and the problems I am having with the rtos preview is making me feel getting a system working is really a full time job, as I have a lot of work to do just getting back to the point I was at a couple of months ago as I have forgotten some of the changes I made to the previous codebase and I really am a newbie to RTOS.
I was looking at integrating an arduino over i2c to offload the stepgen, but dont really know what the best way to do this would be yet.
I hope to mess about with the rtos preview for at least 10 hours this weekend, so maybe will have a lot of questions to ask soon, or I will just give up and realise that that actually adding anything to the linuxcnc project is beyond me!
13 years 11 months ago #26948 by andypugh
mungkie wrote: Unfortunately I also feel linuxcnc has a bias to x86 arch (In fact I get the feeling the project goals state it will only support x86), also the idea of creating lower cost hardware does not leave chance for large profits so does not encourage anyone to work on this as something supporting a business, and possibly pisses a lot of people off as it would put them out of business!
This is a slightly puzzling comment. As far as I know none of the LinuxCNC developers make any money at all from it. It is largely done for fun, which rather means that only the fun bits get done (which is perhaps something of a problem)
13 years 11 months ago - 13 years 11 months ago #26951 by ArcEye
No eBay APP ID and/or Cert ID defined in Kunena configuration
That is just it, you can buy a complete P4 ex corporate desktop for £19.99
I have 3 of these and they return sub 10K latency.
Getting rtai and linuxcnc to run on a low power ARM board with restricted ports and no expansion slots is a fascinating academic exercise, but the practical use is probably only for specialist embedded systems / hobby robotics etc.
Anyone who wants to run a CNC machine, can just buy something like the computer above and have minimum hassle.
Last edit: 13 years 11 months ago by ArcEye.
  • mhaberler
  • New Member
  • New Member
13 years 11 months ago #26952 by mhaberler
Replied by mhaberler on topic EMC2 running on Raspberry Pi?
I'm not so sure about the academic aspect. You might overlook a large potential community out there, the reprap folks, which will eventually graduate from their arduinos once they hit the problems which are already addressed in LinuxCNC. And some of the hardware out there has features which will likely blow away everything PC's can generate in terms in stepping frequency and precision - just see what Bas has done. But it is unrealistic to entice them into using LinuxCNC with the current hardware/architecture/RT OS lock-in.
Relying on junk sales PC hardware and an RT OS base of questionable future is a strategy bound for failure for the LinuxCNC project per se, even if it is a reliable solution for you right now.
I would also think the separation of LinuxCNC into a hard-RT part and a non-RT UI part is a necessary step; the current architecture can go only so long before the build base rots away completely, and we are pretty far down that alley - Ubuntu 10.04 LTS has 5 months to go before the 'LTS' is removed and we're dabbling with a Linux equivalent of Windows XP, and no sequel RTAI kernel in sight. Some rely on hope; that isnt a sound strategy.
- Michael
  • mhaberler
  • New Member
  • New Member
13 years 11 months ago #26953 by mhaberler
mungkie wrote: I compiled the rtos preview for RT_PREEMPT this morning and found that:
I never said this is anything implemented or supported, but if you give an _exact_ command and log we might be able to help. What were you trying to do?
So far I do not even know which platform you are using - if you want to contribute, please send a realistic error report to the developers list. It is very unlikely you find developers in this forum.
A page fault in a realtime thread.
- Michael
13 years 10 months ago - 13 years 10 months ago #27121 by JZHA1985
The crux or issue I am at(others?) is that my old P4 is dying, and I'd rather not have another old salvaged computer that is relatively inefficeint compared to what we have now. So right now things work, but when things finally croak should I shell $150 on an atom board, or get another piece of junk.... (I even considered a smooth stepper for a minute :LOL: )
I don't particularily want anything but a solid controller, having a working self contained unit that is specifcally used for one thing seems key. (I'm almost from a consumers prespective willing to say people would "pay" / donate / kickstarter??? for a port)
I also agree and see that the 3d printer crowd's arduinos will only get them so far, perhaps drawing them here for development purposes would help?
Last edit: 13 years 10 months ago by JZHA1985.
Time to create page: 0.459 seconds
