EMC2 running on Raspberry Pi?
13 years 9 months ago #28333 by mungkie
Just thought I should show the breadboard setup I have done, the mcp23017 is same as on my original soldered protoboard but there is also an atmega 168 which I have been experimenting with.
13 years 9 months ago #28706 by wyzarddoc
I would like to install real time linux on a RPi and use it to schedule the gpio communication only. What software pieces do I need? I do not need the CNC portions of LinuxCNC, nor the HAL portion or do I to run the gpio? I just want a realtime version of raspbian with realtime gpio. Suggestions?
thanks in advance
Doc
13 years 9 months ago #28716 by awallin
wyzarddoc wrote: I would like to install real time linux on a RPi and use it to schedule the gpio communication only. What software pieces do I need? I do not need the CNC portions of LinuxCNC, nor the HAL portion or do I to run the gpio? I just want a realtime version of raspbian with realtime gpio. Suggestions?
thanks in advance
Doc
see this wiki page
wiki.linuxcnc.org/cgi-bin/wiki.pl?NewRTInstall
There might be an existing GPIO-driver that works through HAL. If you code your own using xenomai real-time api/libs you don't need HAL, or even RTAPI - I think.
AW
  • mhaberler
  • New Member
  • New Member
13 years 9 months ago #28719 by mhaberler
Replied by mhaberler on topic EMC2 running on Raspberry Pi?
see this wiki page
AW
there is a basic hal_gpio driver which works on the RPI in this branch. It would benefit from polishing, and speeding up.
- Michael
13 years 9 months ago #28727 by wyzarddoc
Thanks so much for the link. I'll check it out.
13 years 9 months ago #28849 by kinsa
Replied by kinsa on topic EMC2 running on Raspberry Pi?
Did anyone got to compile linuxcnc for the ARM platform besides the simulator mode?
Regards
Time to create page: 0.346 seconds
