Atom 330 or D525 or D510?
13 Jun 2012 00:34 - 13 Jun 2012 06:26 #20862 by gera229
Replied by gera229 on topic Re:Atom 330 or D525 or D510?
Yeah that's what I am concerned about, but at least I saved something. Should I be concerned that I only saved a little?
I got a board that was in like new condition so I'm guessing it wasn't used any longer than a month.
Was it worth it to save about $10 by buying a like new setup instead of a brand new setup?
I do not think my PC will really be on the same table as the CNC machine. But I'll see about that SSD, I'm just peaky with Chinese quality.
Last edit: 13 Jun 2012 06:26 by gera229.
The topic has been locked.
13 Jun 2012 06:21 - 13 Jun 2012 06:26 #20864 by gera229
Also how do I convert the file that I attached to g code.
I attached a file of an enclosure that I want to cut out of wood using a router CNC, not a laser CNC because the services are expensive and I have access to a router CNC so I can do it all by myself.
13 Jun 2012 06:25 - 13 Jun 2012 06:25 #20865 by gera229
Here is the electronics enclosure attached in dxf format.
File Name: CNC_Electr...oser.zip
File Size:88 KB
Last edit: 13 Jun 2012 06:25 by gera229.
13 Jun 2012 09:25 #20869 by ArcEye
Replied by ArcEye on topic Re:Atom 330 or D525 or D510?
Hi
Afraid your zip is corrupted, can't open it.
What you probably want is dxf2gcode
code.google.com/p/dxf2gcode/
13 Jun 2012 10:29 #20870 by andypugh
Replied by andypugh on topic Re:Atom 330 or D525 or D510?
I have had good results with SheetCAM. I am not clear if you are meant to pay for the Linux version or not:
www.sheetcam.com/downloads.shtml
13 Jun 2012 20:27 - 13 Jun 2012 20:37 #20884 by gera229
It doesn't matter as long as I can use it on Windows and transfer it to Linux.
I used a CAM software already and it did not work. Maybe I did something wrong?
It didn't generate every line, and whatever it did do, I didn't get that to convert to G-Code.
I used Pycam.
I attached the drawing files again.
File Name: CNC_Electr...sure.zip
File Size:249 KB
Last edit: 13 Jun 2012 20:37 by gera229.
13 Jun 2012 21:18 #20888 by andypugh
Well, the demo version of SheetCAM is limited, but the Linux version doesn't seem to be.
It has a LinuxCNC post. (In fact, Les is frequently seen about these parts)
13 Jun 2012 22:09 #20890 by gera229
Do you guys have access to the drawing I attached?
Maybe you can convert it for me to G-Code?
Thanks.
13 Jun 2012 22:23 #20891 by andypugh
Sorry, decompression failed. (again)
14 Jun 2012 00:39 - 14 Jun 2012 00:40 #20893 by gera229
I compressed it to zip using winrar and tried opening it on another computer with winrar installed and it worked fine on Windows.
Maybe you can try to install winrar real quick or I can upload the files to a website (idk which one though) that you can download from.
Last edit: 14 Jun 2012 00:40 by gera229.
Time to create page: 0.132 seconds
