Raspberry Pi 4
- Spacehitchhiker42
15 Sep 2019 00:39 #145192
by Spacehitchhiker42
Replied by Spacehitchhiker42 on topic Raspberry Pi 4
drive.google.com/open?id=1JbPiXr_i8be1GWVPG8PJmr7NlOo6WpKD
give it a try now.
password is cnc
i had to ctrl-alt-f1 at the login prompt in order to run raspi-config to expand the filesystem, after that it worked great.
if you run the test configuration, it'll use the gpio header
xdir=3, xstep=5, ydir=7, ystep=11, zdir=13, zstep=15
give it a try now.
password is cnc
- BigJohnT
- Thank you received: 994
15 Sep 2019 13:04 #145241
by BigJohnT
I used a 32Gb SD card...
JT
Replied by BigJohnT on topic Raspberry Pi 4
Sorry, but my 16Gb SD card is not big enough for that image.
JT
- tecno
- Thank you received: 127
15 Sep 2019 13:05 #145242
by tecno
Replied by tecno on topic Raspberry Pi 4
If I had one yes but I do not
- Spacehitchhiker42
15 Sep 2019 13:16 #145243
the new image i just uploaded is shrunk to fit on a 16gb
- tecno
15 Sep 2019 13:49 #145245
by tecno
So far so good.
I can not login in the graphics login window.
ctrl+alt+F1 and I can login.
So how can I get the graphics to work?
- Thank you received: 7417
15 Sep 2019 14:10 #145247
Replied by tommylight on topic Raspberry Pi 4
Try startx after you login to a terminal.
- tecno
15 Sep 2019 14:32 #145250
by tecno
no go
seems that the system is not expanded, never got the question.
- tecno
15 Sep 2019 16:43 #145264
by tecno
at last, did rewrite the sd card. This is from the RPi4
- Gene1934
- Thank you received: 13
15 Sep 2019 16:44 #145266
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Raspberry Pi 4
A quick trip to WallMart and about 12 bucks a copy fixes that, get a 64GB in either Samsung or PNY brands.
I decided long ago that having room enough to let the u-sd wear leveler work was one way to prolong the life of the card. I've had SanDisk 100% failures at 8 and 16 GB, but I've had zero failures of either 32GB or 64GB if i stick to SamSung or PNY.
The last thing you need is to have it go read-only when you've only got a step or three to a working setup. Head that one off at the starting gate.
- tecno
15 Sep 2019 16:48 #145267
by tecno
Sorry no Walmart over here in Sweden and a flight to US and back home tends to be a little extensive for an old fart like me with a very low pension
Time to create page: 0.252 seconds
