Raspberry Pi 4
- The Feral Engineer
- Thank you received: 23
07 Feb 2021 10:46 #197930
by The Feral Engineer
I'm in the same boat as you, I prefer true tactile feedback and already have a project box that I'm going to be building an operator panel from for this machine. I actually wouldn't mind just removing the software jogs and cycle buttons entirely for this build. Maybe I'll have to work on my own gui
Replied by The Feral Engineer on topic Raspberry Pi 4 mmap
That sounds like the system isn't receiving keyup events, for some reason.
Keyboard jogging should only go as far as the axis limits, but that is not much of a safety net if you are jogging Z down.
FWIW I don't trust USB / GUI for jogging any of my machines. It's much more dependable to jog via HAL pins, for example with an MPG.
I have never seen the problems you have, but I am aware of the possibility.
- tjtr33
- Thank you received: 54
25 Mar 2021 05:29 #203601
by tjtr33
Replied by tjtr33 on topic Raspberry Pi 4
I have posted the src file for a new hal_pi_gpio that has
inputs, inverted input
outputs, inverted outptus reset outputs ( allowing double step for rpi opi bpi )
this forum is hard to follow so i have not ( this morning ) found where i posted it .
so, here it is again
the 'easy' way to build it
is to do it in a RIP
( yes thats DOT SPACE before the 's' )
find your old hal_pi_gpio.c file
remove it from 'that place'
store it away for safety
then put my new hal_pi_gpio.c file in 'that place'
then 'touch' it to isure it's 'new' and will be compiledgo back down to the src dir
its only a few seconds to finsih
now use it
in a hal file
that makes pin 3 an ouput with initial value 0 and is resetable
and make pin 5 and output with initial value 1 and not resetable.
and makes pin 11 and input with and additional inverted pin ( th x is just a place holder for nice columns of print )
read the code to see more
some of the pin 'features' are enabled with these {...} sets
so the feature still needs to be turned on
likewill creare a resettable pin
BUT you need to sayto turn on the feature
hth
tomp
cd
cd yourRIPdir
. scripts/rip-environmentfind your old hal_pi_gpio.c file
touch hal_pi_gpio.csudo make modulesits only a few seconds to finsih
now use it
in a hal file
loadrt hal_pi_gpio pi_pins=\
{3,>,0,Y}{5,>,1,N){11,<.+,x}that makes pin 3 an ouput with initial value 0 and is resetable
like
loadrt hal_pi_gpio pi_pins={40,>,1,Y}BUT you need to say
setp hal_pi_gpip.pin-40-out-reset 1hth
tomp
The following user(s) said Thank You: Mike_Eitel, Bari, itai, mwiktowy
- qiwating
24 Jun 2021 19:31 #212860
by qiwating
Replied by qiwating on topic Raspberry Pi 4
thank you very much for the information above, it really helpful for us
- Boaschti
06 Dec 2021 04:15 #228431
by Boaschti
Replied by Boaschti on topic Raspberry Pi 4
Hi gtt38,
can you check my post here: forum.linuxcnc.org/27-driver-boards/4444...-board-for-raspberry
- virencq
12 Dec 2021 00:07 - 19 Dec 2021 23:52 #228902
by virencq
Replied by virencq on topic Raspberry Pi 4
- tjtr33
- All Inputs, Outputs working with reverse, reset functions.
- Thanks again
Last edit: 19 Dec 2021 23:52 by virencq. Reason: All working fine
04 Jul 2022 18:05 #246606
Replied by andypugh on topic Raspberry Pi 4
Was it your intention that this should be merged into LinuxCNC? Did you make a pull request?I have posted the src file for a new hal_pi_gpio that has
- euridium
22 Jul 2022 10:28 - 22 Jul 2022 10:29 #248045
by euridium
Replied by euridium on topic Raspberry Pi 4
I have needed to make some changes to the c code as there are a few errors in pin and gpio assignments.
Not all of the pins are mapped to a gpio and pin 23 was transposed with its neighbour.
I appreciate that this may have been done Intentionally for your needs?
Happy to post the corrected version if anyone is interested?
thanks
thanks
Last edit: 22 Jul 2022 10:29 by euridium.
The following user(s) said Thank You: virencq, mwiktowy
- virencq
17 Aug 2022 12:10 #249960
by virencq
Sir, I am interested to try.
Please share your version.
Time to create page: 0.681 seconds
