Raspberry Pi 4
7 years 2 months ago #143770 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
Mike_Eitel wrote: For cooling
Not yet found time to test.
de.aliexpress.com/item/4000001902776.html
de.aliexpress.com/item/4000035147489.html
Bought the active one and assembly was easy together with controler:
de.aliexpress.com/item/4000051492209.html
This is interesting device, not yet run successfully myself, but using the p3 ssd version.
Would be nice if I could find the English pages. But the last time I ordered from alliexpress, my card was charged, but a small backorder hasn't arrived in something like 3 years. No attempt to contact has been successfull. Banggod OTOH has worked well. But they don't have a working search.
Since I already have a fan on the pi3, that passive kit looks good, as does the sata adaptor and the mini-hdmi. What button do I click to get english?
Thanks.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 2 months ago #143771 by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4
On the right top corner I can choose the country.
I've done lots of orders and had few problems. Opening dispute solved all.
This shop until now, was always reliable and fast.. To Switzerland. ;-)
7 years 2 months ago #143772 by Gene1934
Those patches won't copy/paste here.
Can you fwd them to <gheskett@shentel.net>, or post them in a downloadable format?
Thanks.
7 years 2 months ago #143773 by Mike_Eitel
Patches?
In case you meant me:
Here a link on the global www
www.aliexpress.com/item/4000051492209.html
7 years 2 months ago #143774 by Gene1934
gah, can't get it out of German, nor can I find the add to cart button.
Thanks Mike.
7 years 2 months ago #143776 by svanteg
Replied by svanteg on topic Raspberry Pi 4
Just to report back that the rpi4 is now hooked up and driving the mill. Made a bridge card between the rpi4 and the 7i90 and it’s happy and stable at 31.25MHz. Have made a few parts and no hm2 issues...but some due to running latest linuxcnc master and some due to the rt kernel. Most annoying is that usb seems slightly wonky and can glitch. Hung up once when jogging down... :ohmy:
I’d say it’s ok if you know what you’re doing. I’ll get a pendant hardwired into the 7i90 which will reduce the need to use mouse & keyboard.
Time to create page: 0.154 seconds
