- Thank you received: 183
Mike_Eitel wrote: I tried a few "cable typ" adapters over several month and was never successful. With different ssd's and different image writers like etcher...
I've never been able to make etcher work.
But also pi 3 is only usb-2 the Pi 3 adapter version of that already is a usb-3 solution. Transferring an image is fasssst. And it started until now all kind of imgs i tried.
PI3-version: The connection between both is only via USB. (small special pcb). And you can connect on the 40 pin two wires to have power via that adapter. Also it is not a must.
Ordered already some of the 4 versions, not having any pi 4 in the moment. Too many projects and rare free time..... ;-(
Mike
