- Thank you received: 11
LinuxCNC + Orange Pi (allwincnc)
- Creative25
5 years 6 months ago #207428
by Creative25
Replied by Creative25 on topic LinuxCNC + Orange Pi
Thanks for the hard work.
I have some questions.
Which version of Armbian should I use? The latest?
Do I have to uninstall the previous version of Linuxcnc?
- MX_Master
- Thank you received: 48
5 years 6 months ago - 5 years 6 months ago #207429
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
Latest Armbian Buster. No need to uninstall anything.
Last edit: 5 years 6 months ago by MX_Master.
The following user(s) said Thank You: Creative25
- Creative25
5 years 6 months ago #207463
by Creative25
I tried to install it on a Orange Pi Pc with Armbian 5.10 but there were some error messages:
--- Installing h3cnc
Hit:1 security.debian.org buster/updates InRelease
Hit:2 deb.debian.org/debian buster InRelease
Hit:3 deb.debian.org/debian buster-updates InRelease
Hit:4 deb.debian.org/debian buster-backports InRelease
Hit:5 mirrors.dotsrc.org/armbian-apt buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
--- Installing System tweaks
--- System tweaks successfully installed
--- Installing PREEMPT RT kernel
Installing packages ...
Installing ./armbian/kernel/linux-image-current-sunxi_21.05.0-trunk_armhf.deb ...
linux-image-current-sunxi is already the newest version (21.05.0-trunk).
Installing ./armbian/kernel/linux-headers-current-sunxi_21.05.0-trunk_armhf.deb ...
linux-headers-current-sunxi is already the newest version (21.05.0-trunk).
NOTE: You must reboot the system to complete the installation
--- PREEMPT RT kernel successfully installed
--- Installing LinuxCNC
Installing **./linuxcnc/linuxcnc-uspace_2.8.1_armhf.deb
linuxcnc-uspace-dbgsym_2.8.1_armhf.deb
linuxcnc-uspace-dev_2.8.1_armhf.deb** ...
./install_linuxcnc.sh: line 136: linuxcnc: command not found
ERROR: Failed to install **./linuxcnc/linuxcnc-uspace_2.8.1_armhf.deb
linuxcnc-uspace-dev_2.8.1_armhf.deb package [./install_linuxcnc.sh:137**].
--- Installing ARISC driver for the LinuxCNC
./install_drv.sh: line 44: halcompile: command not found
./install_drv.sh: line 46: comp: command not found
ERROR: Can't find a components compiler for the [./install_drv.sh:49].
--- Installing ARISC configs for the LinuxCNC
ln: failed to create symbolic link '/root/Desktop/configs': No such file or directory
ERROR: Can't create the /root/Desktop/configs link [./install_cfg.sh:125].
--- ARISC configs for the LinuxCNC successfully installed
--- Installing ARISC core firmware
--- ARISC core firmware successfully installed
--- h3cnc installed with errors
--- see the install.log file for details
Are there any missing dependencies?
- MX_Master
5 years 6 months ago #207468
by MX_Master
Try to install `installer/linuxcnc/linuxcnc-uspace_2.8.1_armhf.deb` manually.
And you will see what's wrong with dependencies.
cd installer
sudo apt install ./linuxcnc/linuxcnc-uspace_2.8.1_armhf.deb
- Creative25
5 years 6 months ago #207480
by Creative25
After Installing linuxcnc-uspace_2.8.1_armhf.deb manually the installation finished with only one error message.
--- h3cnc successfully installed
--- reboot the device to complete the installation
Question am I supposed to login as root before installing Linuxcnc? Or is there another reason for this error message?
I have now two Linuxcnc shortcuts on the desktop and can open both of them.
- MX_Master
5 years 6 months ago - 5 years 6 months ago #207512
by MX_Master
Install using non privileged user with sudo. Don't use root.
Found this error's reason inside install_linuxcnc.sh. Already fixed.
Update the installer and install emc again
cd installer
git pull
Time to create page: 1.337 seconds
