- Thank you received: 234
LinuxCNC + Orange Pi (allwincnc)
- Bari
5 years 6 months ago - 5 years 6 months ago #207534
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi
I can confirm that the latest version builds, installs and runs on an OrangePi One with 512MB of RAM. I would not choose this board for anything other than testing. Running a browser takes up all the memory and often stalls or crashes.
Last edit: 5 years 6 months ago by Bari.
- Bari
5 years 6 months ago - 5 years 6 months ago #207535
by Bari
Armbian does NOT use the GPU hardware accel drivers for the Mali400. I tested and installed the latest Buster Armbian_21.02.3_Orangepione_buster_current_5.10.21_xfce_desktop.img.xz
www.armbian.com/orange-pi-one/#kernels-archive-all
It uses LLVM pipe software rendering.
We need to build a version that uses the Panfrost drivers.
- MX_Master
- Thank you received: 48
5 years 6 months ago - 5 years 6 months ago #207545
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
Mali-400 (lima/mesa) isn't a big option to make desktop OpenGL apps works fast. Mali-400's performance is too small and it supports only OpenGL ES.
Mali-T720's (H6 SoC) performance is much better. Already tested with Panfrost. But Mali-T720 supports only OpenGL ES, as H3.
Last edit: 5 years 6 months ago by MX_Master.
- Bari
5 years 5 months ago #207564
by Bari
I also had to turn the Compositing OFF in the desktop settings to speed up desktop movement. Again, I'm using the 512MB Opi One here with H3. Core clock governor at 1200 MHz min and max.
- tjtr33
- Thank you received: 54
5 years 5 months ago #207618
by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi
Hello all
I just installed armbian buster xfce to an OrangePiPluse2e
the got the repo for orangecnc and ran the install script
no problems
it just worked.
then i checked the ini and hal for 3A_test and saw it was safe to run ( no limit switches no estop switch , just xyz step/dir and pwm for a spindle)
I saw it used arisc_pwm for the stepgens and knew it wouyld be using the arisc side of the Opi_2e ( great )
It runs well,
I have AXIS running fullscreen and can pan zoom and rotate quickly while running 3Dchips( tool change removed temporarily , not handled in hal )
I got NO unexpected realtime delays UNTIL i browsed intenet while running AXIS.
I can simply _not_do_that_
thanks MXMaster
send me a pm if you have a way to get you some scratch.
tomp
no problems
it just worked.
It runs well,
thanks MXMaster
tomp
The following user(s) said Thank You: Creative25
- Cncninja
5 years 5 months ago #207643
by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi
I'm very interested to give this a try, but what Orange pi should I get, the Plus 2E is 200usd I may as well buy an RPI and mesa, the Orange Pi PC has a H3 with 1g ram for 30 USD will this run it ok, can I use the onboard HDMI or will that slow it down? Thanks for the insite
