LinuxCNC + Orange Pi (allwincnc)
5 years 4 months ago #211210 by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi (allwincnc)
mwidlok wrote: Thanks MX_Master.
Anyway while I understand (more or less) how the driver + arisc firmware works I am completely missing place where the arisc firmware is loaded to the processor. Could You please explain it a bit? I think that I might be able to help with some minor bugs if You want.
A simple u-boot script (for H3) uploads the firmware to the target SRAM address and starts the ARISC core via special register
github.com/allwincnc/installer/blob/mast...bian/fw/h3/fixup.cmd
This trick works only for H3. The H5 needs a kernel module to upload and start the ARISC core. And none of these tricks works for H6 :) H6 needs another secure method of memory editing
5 years 4 months ago - 5 years 4 months ago #211234 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
3D printer board leverages Allwinner A64’s AR100 core for real-time control
www.cnx-software.com/2021/06/05/3d-print...r-real-time-control/
github.com/intelligent-agent/Recore
github.com/intelligent-agent/Refactor
wiki.iagent.no/wiki/Recore
www.iagent.no/2021/06/04/recore-is-finally-printing/
We can "fix" their project to run LinuxCNC :) on the A64
I have a hard time accepting that they spent two years just to run Octoprint and Klipper on this vs LCNC. Why?
Last edit: 5 years 4 months ago by Bari.
The following user(s) said Thank You: Doogie
5 years 4 months ago #211404 by MX_Master
Doogie wrote: Did you guys see the Recore project which uses an Allwinner A64? I just learned about it and found out that the Allwinner A64 has an onboard micro controller, an AR100(OpenRISC) cpu which the Recore people put Klipper on for doing stepgen. Klipper is only for 3D printers though. If we got Remora onto that AR100/OpenRISC processor then LinuxCNC is your uncle for everything from CNC, 3D printers and laser cutters. Welp, Scott Alford just reminded me that MBed is only for ARM chips and Remora is built on MBedOS so porting it to the OpenRISC/AR100 wouldn't be an easy task. Darn, the versatility of full LinuxCNC on Remora(or Mesa) is the bomb.
This project (allwincnc) can be used on A64 boards too. A64 it's a H3 with tiny changes :) But I never tested it on A64 (has no such boards). The firmware (allwincnc, AR100, OpenRISC, ARISC) is already fully optimized for the fast realtime tasks, no need to port anything.
5 years 4 months ago - 5 years 4 months ago #211414 by MX_Master
MX_Master wrote:
mwidlok wrote: What is the status of "encoder" module for H3?
I'll try to fix all errors as soon as possible ;)
All the general bugs were fixed. Tested with simple 80PPR encoder. mwidlok, you can continue.
Any other people can join the testing :) Driver docs are here - allwincnc.github.io/docs.html . Simple HAL file to test a single encoder is here - github.com/allwincnc/linuxcnc/blob/maste...isc-encoder-test.hal
Last edit: 5 years 4 months ago by MX_Master.
5 years 4 months ago #211419 by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
I see the encoders talked about a lot, this is really only for servo systems right? If im running a stepper or closed-loop servo looped only with the drive then encoder inputs are irrelevant correct? or is the stepper signal feedback through an encoder to verify stepper count?
5 years 4 months ago #211423 by MX_Master
Cncninja wrote: I see the encoders talked about a lot, this is really only for servo systems right? If im running a stepper or closed-loop servo looped only with the drive then encoder inputs are irrelevant correct? or is the stepper signal feedback through an encoder to verify stepper count?
High resolution encoders and linear encoders uses for the DIY high accuracy realtime position feedback (closed loop). Medium resolution encoders uses in mechanical handles. Small resolution encoders uses in some control panels to increase/decrease spindle RPM, cutting speed, etc.
Time to create page: 0.247 seconds
