LinuxCNC + Orange Pi (allwincnc)
- viewtop1
5 years 4 months ago #212343
by viewtop1
Replied by viewtop1 on topic LinuxCNC + Orange Pi (allwincnc)
Mmm, I flashed an image form the mirrors.tuna.tsinghua.edu.cn
(Armbian_21.05.1_Orangepiplus2e_busterxxx) and it works…
Weird.
Weird.
- MX_Master
- Thank you received: 48
5 years 4 months ago #212377
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi (allwincnc)
OK. It's time for the full replacement of uboot script (firmware loader) to the kernel module. Need some time to do that.
- viewtop1
5 years 4 months ago #212388
by viewtop1
Here is the Serial Console output from the failed loading of the latest Armbian ( after ./install_fw.sh)
Thankfully using an older image seems to work fine.
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
1275 bytes read in 3 ms (415 KiB/s)
Applying user provided fixup script (fixup.scr)
Found the ARISC firmware blob `/boot/arisc-fw.code`
Base Address: 0x00000000
asserting the ARISC core reset..
asserting reset done, trying to upload the blob to the SRAM A2 (0x00040000)..
21628 bytes read in 3 ms (6.9 MiB/s)
uploading done, de-asserting the ARISC core reset..
de-asserting reset done, the ARISC core is ON.
## Loading init Ramdisk from Legacy Image at 43300000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 14645706 Bytes = 14 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
7[r[999;999H[6n8Scanning disk mmc@1c0f000.blk...
Card did not respond to voltage select! : -110
Scanning disk mmc@1c10000.blk...
Disk mmc@1c10000.blk not ready
Scanning disk mmc@1c11000.blk...
** Unrecognized filesystem type **
Found 18 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
3967 bytes read in 3 ms (1.3 MiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
202 bytes read in 2 ms (98.6 KiB/s)
14645770 bytes read in 607 ms (23 MiB/s)
8090200 bytes read in 337 ms (22.9 MiB/s)
Found mainline kernel configuration
33211 bytes read in 6 ms (5.3 MiB/s)
4185 bytes read in 6 ms (680.7 KiB/s)
1275 bytes read in 2 ms (622.1 KiB/s)
Image Name: uInitrd
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete........ done
BOOTP broadcast 1
The following user(s) said Thank You: MX_Master
- viewtop1
5 years 4 months ago #212391
by viewtop1
On a side note... Would it ever be possible to use some of the other Linuxcnc GUI options?
Specifically qtdragon or Probebasic? or any QTpyVCP types?
I tried, to install them but it seems VTK is not supported in Armbian.
- MX_Master
5 years 4 months ago #212395
by MX_Master
It's Armbian based feature. If you can get the VTK, you'll have a desirable interface. But performance of these boards is not a perfect point to run something heavy.
- envyvan
- Thank you received: 3
5 years 4 months ago #212893
by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi There,
I try to install the project to my board, But seems like the github of this project is empty now.
Time to create page: 0.171 seconds
