LinuxCNC + Orange Pi (allwincnc)
5 years 3 months ago #213685 by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
I have a question with the config.hal file.
looks like the hal file already use the "setp" to set the pin value, so I don't need to use the "net" to setup the pin for pwm and dir.
Am I right?
But I also see there also using the net for setup the pin for enable funtion.
5 years 3 months ago #213708 by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi (allwincnc)
github.com/allwincnc/installer/blob/mast...t/config.hal#L21-L27
1. arisc.pwm.N.pwm-port / arisc.pwm.N.pwm-pin uses like input parameters.
2. arisc.gpio.XXX-out uses like output signals
The following user(s) said Thank You: envyvan
5 years 3 months ago #213743 by envyvan
Therefor, I should still use the "net" to sign up the pin number which is connect to the output function. like the DIR/STEP or etc..
5 years 3 months ago #213852 by envyvan
I have play around the system few time, When I runing the NC program and open some other windows like LinuxCnc Status to watch the parameter and setting, It will shows up "Joint 1 following error."
5 years 3 months ago - 5 years 3 months ago #213872 by Bari
Last edit: 5 years 3 months ago by Bari. Reason: fixed link
5 years 3 months ago #215339 by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Hi! What's the status of this project on H5? Is it usable? I'm having problem with my PC motherboard and latency spikes. Is it usable at the actual stage?
Time to create page: 0.813 seconds
