LinuxCNC + Orange Pi (allwincnc)
5 years 3 months ago #215957 by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
Hello my friends, I'm talking here from Brazil!
For us this project will be a great help, because the Mesa interfaces, even the simplest ones, arrive in my country for 2x the value in USD due to import taxes! while an orange Pi PC is only about 57USD!
Is the low performance of h3 chips with 1gb ram a big problem? any custom screen instructions to make it lighter?
Sorry for my bad English!
5 years 3 months ago #215961 by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Fala vizinho!
I've got an Orange Pi Prime (H5/2GB) for myself. Unfortunately ARISC status wasn't know by me at the moment of purchase. I would like to know how good is the performance with these H3/2GB if you ever got one.
Today I will test GPIO on H5. I wanna make a small donation to the project author and strongly suggest others to do the same. It may speed up the things a little bit, or at least attract some attention to ARISC support on H5.
5 years 3 months ago #216103 by taylorcmq
from what I could notice the support for h5 is not 100% completed but h3 seems to work well, but I'm waiting for some user who has tested to inform something about the performance if it is possible to run and what are the limitations
5 years 3 months ago #216106 by Dolence
I got another board, an H3 this time. I'm having joint following errors and couldn't figure out how to make it work properly. My easy servos are set to 32 microsteps and I'm testing with speeds way lower than on PC motherboard which in theory should be slower generating steps. Tomorrow I will post my configuration files to see if we can figure out what is going on together! Thanks in advance.
5 years 3 months ago #216108 by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
I received the ALL-H3-CC today!!
5 years 3 months ago - 5 years 3 months ago #216122 by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi (allwincnc)
Hello, has port 6 been tried with pwm stepgen?
I am having no luck with PG7 as step and PG6 as dir.
I am using 3.3/5v converters between OPi 2e and Lichuan servostepper drives.
I made a config with PG7 ( port 6 pin 7 ) for step and PG6 ( port 6 pin 6 ) for dir,  but I get no pulses.
( no voltage change on STEP or DIR, i expect 0 or 5v on DIR and between 0 and 5 for the step stream)
Is port 6 correct for port G ?
So I made a test hal file with arisc.gpio.PG7-outand arisc.gpio.PG6-out and named the nets xs and xd resp.
Then,  via halrun. was able to step in either direction
I'm thinking that the 'pwm stepgen' doesnt like PG6 PG7 ( or me ;)
the testgpio.hal is for use with halru
'the config.hal is for use with 3Aconfig
thx tomp
Last edit: 5 years 3 months ago by tjtr33. Reason: typo misscount register number
Time to create page: 0.210 seconds
