LinuxCNC + Orange Pi (allwincnc)
5 years 3 months ago - 5 years 3 months ago #216188 by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi (allwincnc)
Hi
re following errors
I suggest trying the supplied 3Atest config
I suggest editing /boot/armbianEnv.txt by adding
"extraargs=isolcpus=1,2,3 idle=poll"
I suggest that latency doesnt mean a damn thing
because i use arisc stepgen which is used in 3Atest
( the arisc side of the opi brain is not affected by latency afaik )
My tests run all night and i do not get Unexpeced realtime delay erros
(UXRTdelay).
I do not get following errors.
My scale and acc are based on my
system ( scale = 2666.66666 becuz i am metric,1/16step, 1.5 pitch screw,
direct coupled motors, 200step/rev motors, and acc = 600.
Your system will not use thes values unless you have the same
transmission.
I have used this to test 2 different styles of nema17 with tmc2130 drives in standalone mode, at 1/16th step. I got 29.4666mm/sec with 1/16 microstepping reliably ( thats an amazing pulse per second rate )
My 'reliably' is a test program moving +/-80mm 100 times and returning to same shaft angle ( tie wrap on shaft aligns to magic maker mark on body )
One set of 'hi torque nema 17' motors gave me 1350mm/min , another set gave me 1768mm/min.
All test done with a set of 3 motors each,
all with same tnc2130,
but current on small motors was 0.8vref and 0.98vref on larger motors.
Tests results are repeatable BUT not loaded.
I am hitting the motor limits, not opi/allwincnc limits.
I am now trying lichian 3phase stepservos but have difficultly is using Port G for the step and dir.. thats another story.
SO, yes others do use the OPI, I use OPi+2e with 2G.
I do NOT tease the bears,
my cnc control is not for web browsing or watching 4K Netflix.
I think that is reasonable.
my 2c.
ps: my  /etc/default/cpufrequtils  shows
mnin and max cpu freq both at 1008000
governor = performane
you can set those with armian-config
pps: i use a 1inch square alum heat sink above cpu and some other chips
with a 12V fan right in top
you HAVE to coole these pi's (opi rpi bpi)
hth
tomp
Last edit: 5 years 3 months ago by tjtr33. Reason: add cpu freq tested at, cooling note. typo
5 years 3 months ago #216191 by tjtr33
values of what? latency?
latency is irrelevant if using arisc pwm-stepgen
well, just as irrelevant as when using mesa or pico external stepgens.
if you worry about following errors,
look into your max vel, and acceleration settings,
maybe make your thread speed same as supplied 3Atest config.
hth
tomp
The following user(s) said Thank You: Dolence
5 years 3 months ago - 5 years 3 months ago #216205 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Latency is relevant if one is getting real time delay errors and they don't have the cpu clocks locked at one speed.
The following errors are likely explained in the links I provided earlier.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
forum.linuxcnc.org/38-general-linuxcnc-q...or-on-stepper-system
The u-boot firmware should be built to force the cpu into a good working state for most users. Experienced devs may build what they wish. The real time kernel should also be configured for lowest possible latency while supporting all the required features for a LCNC system. Both currently are not.  Users should not be expected to edit /boot/armbianEnv.txt by adding
"extraargs==isolcpus=1,2,3 idle=poll"
Last edit: 5 years 3 months ago by Bari.
5 years 3 months ago - 5 years 3 months ago #216267 by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Thank you very much for all the help. It is really very appreciated!
Ok, so today I run a few more tests...
Fixing the CPU min and max frequency to the same value and adding isolating CPUs editing /boot/armbianEnv.txt like this solved my latency issues.
I still getting the joint following errors. Even with out of the box configuration files (just adding the option to ignore homing) I still getting this error. So far I've tried to use higher values for FERROR and MIN_FERROR and adding STEPGEN_MAXVEL and STEPGEN_MAXACCEL values 20% higher than MAX_VELOCITY and MAX_ACCELERATION, but none of these helped.
[TRAJ] COORDINATES =  XYZ LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 15.0 MAX_LINEAR_VELOCITY = 150.00 NO_FORCE_HOMING = 1 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_X] MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 STEPGEN_MAXVEL = 187.50 STEPGEN_MAXACCEL = 937.50 SCALE = 256.0 FERROR = 10.0 MIN_FERROR = 1.0 HOME_OFFSET = 0.0 [AXIS_Y] MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 [JOINT_1] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 STEPGEN_MAXVEL = 187.50 STEPGEN_MAXACCEL = 937.50 SCALE = 256.0 FERROR = 10.0 MIN_FERROR = 1.0 HOME_OFFSET = 0.0 [AXIS_Z] MAX_VELOCITY = 100.0 MAX_ACCELERATION = 200.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 [JOINT_2] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 MAX_VELOCITY = 100.0 MAX_ACCELERATION = 200.0 STEPGEN_MAXVEL = 120.0 STEPGEN_MAXACCEL = 240.0 SCALE = 160.0 FERROR = 10.0 MIN_FERROR = 1.0 HOME_OFFSET = 0.0
It doesn't matter much at this moment since I'm getting the same error with provided example configuration, but my real hardware is as follow:
1.8 degree 200 steps per revolution Easy Servos on X, Y and Z
X and Y screw pitch are 25mm per revolution
X and Y microsteps = 32
Z screw pitch is 20mm
Z microsteps = 16
Last edit: 5 years 3 months ago by Dolence.
5 years 3 months ago #216311 by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
SCALE = 256.0
I think this value is quite fast for a hobby cnc.
If I don't get it wrong, SCALE should be how many pulse for 1mm or inch, then you set up the VELOCITY to 150mm per second.
I not sure the H3 CPU would able to handle it.
And I also notice AXIS GUI seems like to show up quite much warning and error which tklinuxcnc GUI does not.
5 years 3 months ago - 5 years 3 months ago #216313 by tjtr33
Hi Dolenece,
i reply inline....
>>> so no more Unexpected RealTime Delays?
>>> did you fix ( nail down ) the cpu speed?
>>>You can use Armbian-config to set the min and max to the same value
>>>and choose the governor as performance
>>> the arisc_pwm_stepgen is not the same animal as linuxcnc stepgen
>>> the arisc criiter doesnt have the same params, so dont add flippers onto a cat.
>>> dont add stepgen_max_accel etc to arisc stepgen
>>> some ferrors could be due to a varying cpu speed, see above
>>> did you follow the urls send by Bari concerning following errors?
[TRAJ] COORDINATES = XYZ LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 15.0 MAX_LINEAR_VELOCITY = 150.00 >>> ok so thats 4500 mm/minute NO_FORCE_HOMING = 1 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_X] MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 >>> i have not tried 750 acc but it does not sound crazy high, as i used 600 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 MAX_VELOCITY = 150.0 MAX_ACCELERATION = 750.0 STEPGEN_MAXVEL = 187.50 >>> hey! there is no stepgen_maxvel in an arisc pwm_stepgen >>> if you are using standard linuxcnc stepgen on an opi >>> the you will have very low steprates, low acc, and no experience from me >>> ditto for stepgen_maxaccel >>> please use linuxcnc stepgen OR arisc pwm_stepgen NO MIXING STEPGEN_MAXACCEL = 937.50 >>> scale is correct for 25mm pitch 1.8degree stepper 1/32 uSteps SCALE = 256.0 FERROR = 10.0 MIN_FERROR = 1.0 HOME_OFFSET = 0.0 >>> dont worry about Y or Z untill X can be tormented without ferrors [AXIS_Y] ...snip... It doesn't matter much at this moment since I'm getting the same error with provided example configuration, but my real hardware is as follow: 1.8 degree 200 steps per revolution Easy Servos on X, Y and Z X and Y screw pitch are 25mm per revolution X and Y microsteps = 32 Z screw pitch is 20mm Z microsteps = 16 >>>summary >>> read the ferror docs >>> please fix (nail down) the cpu freq >>> please adapt a supplied config.ini, dont add items that did not exist in original >>> try 1 thing at a time, and post your results hth tomp ps: somebody explain to me how to include the orig text in this goofy editor ( forum editor ) i swear there used to be a button
Last edit: 5 years 3 months ago by tjtr33. Reason: stupid editor, stupid editer
Time to create page: 1.374 seconds
