LinuxCNC + Orange Pi (allwincnc)
5 years 3 months ago - 5 years 3 months ago #216405 by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
It's weird, but I just noticed that if I launch linuxcnc over ssh using Xserver forwarding (Xming putty on Windows) the code run almost entirely without errors. Usually it pops after a few seconds of moviment, but this time it almost run entirely. I didn't stop the lightdm service on the Pi board, just launched the AXIS UI over SSH on my local network.
Last edit: 5 years 3 months ago by Dolence.
5 years 3 months ago #216417 by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Dolence,
Thanks for you explain, I have slow system that on the opposite side from you.
I also have the same error with stock configuration (3A_TEST example) same as you.
But I run the 3T_Test configuration with no error. So I guest CPU of the pi was not handle the AXLE GUI well.
The following user(s) said Thank You: tjtr33
5 years 3 months ago #216424 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Is it using software or hardware rendering? More little things to add up to does it work well or not. It just needs a good going over and some cleanup.
5 years 3 months ago #216428 by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi (allwincnc)
Dolence, Bari
The latest repo is allwincnc.github.io/
i know there were 2 other attempts at repos
but the above is the most up to date afaicy.
unforch there is a notice
NEWS:
30.07.2021: The project was archived.
25.06.2021: Actual project installer make your board unbootable on latest Armbian_21.05.1 with Linux kernel v5.10.34. Use an older images if possible.
13.06.2021: Increased encoder's position/velocity accuracy (thanks to M.Widlok)
07.06.2021: Added full support of ABZ encoder
i hope archived != cold storage.
so, i dunno where we are but hope that I can use the last version I downloaded,
and that in the future, the boot problem is solved and the project can progress.
For my self I am tossing my latest opi/TSX0108e in the grbg and hand wiring
my opi+2e to leadshine 3phse stepppers. Sounds easy but i can hardly
see these tiny wires and dupont pins anywore. Well, i can do it till i go blind ;-)
damn grey text on paper white bg damn!
my screen has nose prints on it.
tomp
5 years 3 months ago #216431 by tjtr33
Thanks Bari,
how do we check which method is used for rendering?
Which one is the one we want for arisc-pwm-stepgen?
I thought it was in armbian-config but no.
i migth be remebering raspbian-config or a dream.
1 hr googling and i see i dont know how to ask the question..
ambian video rendering? h3 video rendering? no luck
tomp
5 years 3 months ago #216432 by tjtr33
Dolence
you have already done what i suggested
i will read the post Bari mentioned and see if i can suggest anything.
Remind me though, what board, what memory, and do you know if parrt of that memory is taken by the video system?
btw when i issue uname -r
i get
5.10.21-rt34-sunx1
I dont know how to evalute your result but at least we have some fixed info
about what envirinments are.
tomp
Time to create page: 0.331 seconds
