LinuxCNC + Orange Pi (allwincnc)
5 years 3 months ago #216486 by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
So the ALL-H3-cc is all loaded up everything went great then when it asked for the reboot it boots up to " :~$ " any ideas?
5 years 3 months ago #216523 by Cncninja
ok got into it with
startx
5 years 3 months ago #216544 by Cncninja
ok so it running and I can cut the Linuxcnc logo no problem, but if I load one of my g codes it just sits there ( linuxcnc post-process fusion360.) and is locked up have to close and re-open.
5 years 3 months ago #216561 by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi forks,
I do agree with Bari. We have to do some optimize with Armbian.
I think this project have great value for the people living in the place not easy to get the MESA BORAD.
I'm very appreciate MX_Master done such great job for made it happen.
5 years 3 months ago #216603 by Cncninja
File Name: testgcode.zip
File Size:1,124 KB
Could someone else try the code so i can see if it's the config or the gcode. the system runs the linuxcnc tool path fine but will not run anything I load.
5 years 3 months ago #216605 by envyvan
Hi Cncninja,
T1 M6 is a g-code command that tells the mill to use tool index 1 (see Note above), and M6 tells the virtual machine to go to its tool change position and execute the tool change.
If you don't set to use this funtion, should remove it from your Gcode.
Time to create page: 0.613 seconds
