- Thank you received: 3
LinuxCNC + Orange Pi (allwincnc)
- envyvan
5 years 2 months ago #216875
by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
I only running this project on Armbian_21.02.3 and seems like it works just fine with me.
I will keep work with it until most of the function has been test.
A notice issue is halui would cause a warning, but seem like every thing run normal.
- tjtr33
- Thank you received: 54
5 years 2 months ago - 5 years 2 months ago #216907
by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi (allwincnc)
Hi Dolence
I am running
Armbian_21.02.3_Orangepiplus2e_buster_current_5.10.21_xfce_desktop
on an Opi+2e, with HDMI output and logitec wireles usb kbd & mouse
from a SanDisk 32G sd card ( class A )
I use isolcpus=1,2,3 idle=poll
I am using Lima video ( thru no effort on my part, it was automatic)
I am running Lichuan LCDA357H/ LC57H38 stepservos right now in a test rig
at 1588rpm with 1/4 step and 100 acceleration. Trying for faster, but have occasional amp faults that i havent figured out yet.
My setup is not ready for real use use yet. The OPi is running fine tho.
tomp
I am running
tomp
Last edit: 5 years 2 months ago by tjtr33. Reason: clarify
- Cncninja
5 years 2 months ago #216914
by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
thanks ill try
- Cncninja
5 years 2 months ago #216915
by Cncninja
owe this was the link to use from Bari from the last page
"H3 has a Mali400 so try to use the Panfrost/Lima drivers.
wiki.debian.org/MaliGraphics
H3
linux-sunxi.org/H3
You need to run a heatsink and you don't want the CPU core speeds to change/throttle. So you need a good heatsink and to the lock the CPU speed governor at ONE speed."
H3
linux-sunxi.org/H3
- Cncninja
5 years 2 months ago #216917
by Cncninja
- Dolence
5 years 2 months ago #216927
by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
No matter what, I always end with joint following error. Fresh install, isolcpus, cpu=idle, max freq locked, governor=performance, default conf filles and the error persists. Tried on AXIS and the TK one.
Someone using the 1GB Orange PI PC with success can upload his current ISO, please? I'm considering some kind of hardware flaw, because I've tried everything... Different armbian versions, iI just can't make this work without throwing joint following errors while running the file.
Time to create page: 0.401 seconds
