LinuxCNC + Orange Pi (allwincnc)
5 years 2 months ago - 5 years 2 months ago #216828 by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
These aren't for H3. Our boards use the Mali 400, which should be working with the already installed Lima drivers out of the box. Unfortunately it seems to be not performing as expected. I read somewhere that the older proprietary Mali drivers could reach 300+ fps in glxgears. Unfortuantely it only works in very ancient kernels.
Should I use this to install from that page, or do I need a variant for ARM?
apt install mali-t76x-x11-driver
apt install mali-t76x-wayland-driver
apt install mali-t76x-fbdev-driver
Last edit: 5 years 2 months ago by Dolence.
5 years 2 months ago #216830 by Dolence
What's the armbian version you are using?
I use the encoder funtion to connect the MPG Jog wheel.
Not the one for feedback.
I'm not sure the SOC board have enough CPU power to do the real encoder close loop stuff.
5 years 2 months ago #216833 by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Dolence,
I currently runing with Armbian_21.02.3_Orangepipc_buster_current_5.10.21_xfce
5 years 2 months ago #216834 by Dolence
I'm asking because Michael wrote this on Russian forum:
In general, H3 is no longer supported normally. For in the uboot (bootloader) code, developers are constantly muddying up various new items that interfere with the work with the coprocessor.
I wanna know which Armbian version you guys are using with your working H3 boards. Which version is the latest supported or known to work with the current version of this project?
5 years 2 months ago #216857 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Why I mentioned that we need our own u-boot branch for this project since those devs usually could care less about real time. We could ask them to stop stomping all over the memory space for the ARISC if that is the real issue. They might not even be aware of anyone using them.
5 years 2 months ago #216871 by Bari
I used to write firmware for x86 (BIOS, coreboot, etc) and work with u-boot. I am actually more comfortable with firmware than writing applications in abstract languages. i prefer 1's and 0's.
The following user(s) said Thank You: envyvan
Time to create page: 0.315 seconds
