LinuxCNC + Orange Pi (allwincnc)
- Bari
- Thank you received: 234
05 Aug 2021 10:29 - 05 Aug 2021 10:39 #216959
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
True it uses the servo thread but people are getting real time errors due to too much jitter.
Why posting config files and comparing to those without real time errors should help clear this up.
Months ago it was discovered "On a OPi+2e booted with isolcpus=1,2,3 idle=poll and the speed forced to max."
forum.linuxcnc.org/18-computer/39037-lin...ncnc?start=80#194567
forum.linuxcnc.org/18-computer/39037-lin...ncnc?start=90#200199
"I also had to turn the Compositing OFF in the desktop settings to speed up desktop movement. Again, I'm using the 512MB Opi One here with H3. Core clock governor at 1200 MHz min and max. "
forum.linuxcnc.org/18-computer/39037-lin...cnc?start=140#207790
Last edit: 05 Aug 2021 10:39 by Bari.
The following user(s) said Thank You: envyvan
- envyvan
- Thank you received: 3
05 Aug 2021 11:33 - 05 Aug 2021 13:09 #216965
by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Bari,
Yes, I notice that if I open a browser will lead to unexpected realtime dalay issue.
But other then that, Why I need to do other job on such small board?
I would just use it on the motion control, as long as it wouldn't fail the job on the halfway.
Please see attached for my config file.
Last edit: 05 Aug 2021 13:09 by envyvan.
- Dolence
05 Aug 2021 17:00 - 05 Aug 2021 17:38 #216994
by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Thank you for posting your configuration. I've tried using your files and the same joint following error occurs. I think it may be related to recent changes in the project source git after you have your installation done. Yesterday I even managed to install Armbian Focal image on another card. Lastest Focal version does have Lima accelerated graphics out of the box. I was expecting it would offload the CPU. Get everything working was a little tedious. I had to manually download lots of packages to solve linuxcnc dependencies until the installation script finished without errors resulting in a working environment. Now I have an working Ubuntu Focal and a Debian Buster installations.
I know it's a too much to ask, but I would know if someone with an Orange Pi PC (not the plus version) running without joint errors would kindly generate an image of his working SD card and upload somewhere. This way I can eliminate any hardware related problems, like bad quality SD cards or a defective board itself. I don't believe it is the case, I'm more inclined to link my problem to something software related. Once I have this figured out I can try to contribute compiling a new RT Kernel, doing some tests with the Mali binaries (they are mainline now) which seems to be more stable and fast, etc.
Hi Bari,
Last edit: 05 Aug 2021 17:38 by Dolence.
- envyvan
05 Aug 2021 23:50 - 06 Aug 2021 05:53 #217017
by envyvan
Hi Dolence
I'm happy to help, because I think this project is such helpful for me and also for people who want fast STEP speed but with out MESA board.
Have you try the ISO that I clone from my SD card below? It for Orange PI PC 1G memory version.
drive.google.com/file/d/1D3RlYBO9vscBJYZ...1f3/view?usp=sharing
Last edit: 06 Aug 2021 05:53 by envyvan. Reason: Update the sharing link
- taylorcmq
06 Aug 2021 04:19 #217023
by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
Hello, I requested the download, the file is blocked.
- wzor
06 Aug 2021 05:34 - 06 Aug 2021 05:49 #217027
by wzor
Replied by wzor on topic LinuxCNC + Orange Pi (allwincnc)
By run you mean you can open an ngc file and run it from the start to finish or just manually move the axis?
NGC problem(
Last edit: 06 Aug 2021 05:49 by wzor.
- Bari
06 Aug 2021 05:46 - 06 Aug 2021 05:47 #217028
by Bari
@wzor Please post your config.INI and .HAL files as well as any kernel config lines and version of Armbian and how you built it.
isolcpus= , idle-poll etc etc
Thank you!
Thank you!
Last edit: 06 Aug 2021 05:47 by Bari.
- wzor
06 Aug 2021 05:50 #217029
by wzor
Bari, sorry ngc problem(((
- envyvan
06 Aug 2021 05:59 #217030
by envyvan
Link is update, Should be ok to download now.
- taylorcmq
06 Aug 2021 13:38 #217060
by taylorcmq
thanks, my board arrives today i will start testing!
Time to create page: 0.174 seconds
