LinuxCNC + Orange Pi (allwincnc)
- Cncninja
02 Aug 2021 14:02 #216698
by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
Thanks, my other cnc just has a pop up to hit a key to contiue. I remover that line and it started to go.
- Cncninja
02 Aug 2021 14:04 #216699
by Cncninja
I'm getting the realtime delay error on task 1 with period 1000000.. i have not tried the gl driver yet
- taylorcmq
02 Aug 2021 17:00 #216713
by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
which model of your card?
- Dolence
02 Aug 2021 17:41 - 02 Aug 2021 18:02 #216717
by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Hey guys, many thanks for the follow-ups!
It seems using hardware acelerated graphics increase greatly the performance and solves the issues, right?
After some reading and testing I noticed I couldn't use the older instructions with the newer kernels on more recent armbiam images. Those instructions are dated from 2016. I saw more recent instructions for having it working on newly versions and I'm trying it right now. Anyone which had success with this can describe which process was sued, please? Also, lima drivers shouldn't offer hardware acceleration?
I'm also considering using an older image with older kernel for some tests.
Last edit: 02 Aug 2021 18:02 by Dolence.
- Bari
- Thank you received: 234
02 Aug 2021 18:18 #216724
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
H3 has a Mali400 so try to use the Panfrost/Lima drivers.
wiki.debian.org/MaliGraphics
H3
linux-sunxi.org/H3
You need to run a heatsink and you don't want the CPU core speeds to change/throttle. So you need a good heatsink and to the lock the CPU speed governor at ONE speed.
H3
linux-sunxi.org/H3
- Cncninja
03 Aug 2021 13:48 #216820
by Cncninja
it's a Libre ALL-H3_CC 1GB (Tritium-h3), Full Armbian support
www.armbian.com/tritium-h3/
- Cncninja
03 Aug 2021 13:51 #216822
by Cncninja
Hey Bari,
is there a post to show how to lock speed?
- envyvan
- Thank you received: 3
03 Aug 2021 13:51 #216823
by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Forks,
Good day.
I have playaround the encoder function today and there is one issue I found with the input pin function.
I can't use the "setp arisc.gpio.PG6-pull -1" to pull the pin to ground, It mean the encoder number keeping counting, still has 0.6V on the pin.
And also seem like the encoder only likes to counting at HIGH, I need to use the pull down resistor with input pins.
But If I check the pin which is sign to the Stepper Enable pin or the DIR pin, they can set to low correctly.
I wonder If MX Master have some luck to look on it, But I realize they talk about the encoder function before, I wonder how they set there hardware and parameter.
Good day.
- Cncninja
03 Aug 2021 13:57 #216824
by Cncninja
Should I use this to install from that page, or do I need a variant for ARM?
apt install mali-t76x-x11-driver
apt install mali-t76x-wayland-driver
apt install mali-t76x-fbdev-driver
- Cncninja
03 Aug 2021 13:59 #216825
by Cncninja
is this for real encoders or the virtual feedback encoder?
Time to create page: 0.499 seconds
