LinuxCNC + Orange Pi (allwincnc)
- taylorcmq
10 Aug 2021 14:55 #217404
by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
I understand, I was running the SD card test myself, I'm going to do a new installation in the orange PI PC memory
- Dolence
10 Aug 2021 20:43 #217421
by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
Tested the Lima enabled Ubuntu image today. Disabling effects turns things much more snapier. Still having joint following errors. I don't know... It need to be something hardware related. Some guys are running on 512 MB H3 and I can't. I'm going mad.
- Bari
- Thank you received: 234
10 Aug 2021 20:51 #217422
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
512MB on the H3 runs slowly if you don't open a browser. 1GB or RAM is the minimum I'd use.
If you slow down the acceleration and max speed do you still get joint following errors?
- Dolence
16 Aug 2021 18:11 #217908
by Dolence
Yes, even with minimum speed/accel I'm getting errors.
- envyvan
- Thank you received: 3
17 Aug 2021 07:16 #217960
by envyvan
Would you mind to upload the config file,and let's see what happen?
And which system you are currently running?
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Dolence,Yes, even with minimum speed/accel I'm getting errors.
- Bari
18 Aug 2021 21:11 #218093
by Bari
www.aliexpress.com/item/1005001823662622.html looks like the latest Opi board.
Uses Allwinner H616 linux-sunxi.org/H616 "Apparently it has no CPUS (ARISC management processor) anymore, also is missing the associated SRAM A2. "
SO AVOID THIS MODEL FOR LCNC!
- 109jb
- Thank you received: 15
16 Sep 2021 03:22 #220756
by 109jb
Replied by 109jb on topic LinuxCNC + Orange Pi (allwincnc)
I am very very interested in this project and have scanned through all pages of this thread but I cannot determine if this project is at a state where it is usable. Can someone who may be more familiar with the project tell me if it is in usable state for a basic 3-axis stepper driven mill. Also is the allwincnc.github.io/index.html site up to date in terms of installation instructions?
Thank you in advance
- Bari
16 Sep 2021 03:35 #220758
by Bari
It works, but you need to know how to build LCNC, preempt_rt kernels and u-boot properly for this to be stable. There were some versions on the original devs github that worked but he gave up on the project after he claimed that the Armbian devs made some changes frustrating his efforts to access the memory space for the integrated microcontroller. Not sure of all the dramatic details.
It just needs someone with enough time and skills to put together a turn-key image for those that need everything done for them vs being able to build from source without having their hand held.
- 109jb
16 Sep 2021 15:35 #220802
by 109jb
Thanks. Since I broke my leg last Saturday and needed something to do to occupy my time I ordered a Orange Pi One H3 that should arrive today to try this project . Kind of did it on a whim after only reading a few pages of this thread. Probably should have read further and would have seem that there were potential problems, but since I have a board coming and I have time on my hands I will give it a try. It has been many years but I was able to build from source way back when LinuxCNC was EMC2, but I haven't done anything like that since the precompiled images have been available. We'll see.
As a start, I see on the Armbian site there are Focal, Buster, and Bullseye versions. Would one or the other of these be preferred to minimize install issues?
- 109jb
16 Sep 2021 18:50 #220810
by 109jb
I guess I can test this as well, but figured someone probably knows off the bat.
My machine currently has a parallel port breakout board like this one www.amazon.com/DollaTek-Breakout-Optical...id=1631818031&sr=8-4
My intent is to retain the parallel port breakout board and construct a cable to interface the GPIO on the OPi to the PP BOB. So the question becomes: Will the 3.3v GPIO be able to work with this or will I need to build a hat with logic level converters to be able to use it?
Time to create page: 0.437 seconds
