LinuxCNC + Orange Pi (allwincnc)
- wzor
5 years 2 months ago #216935
by wzor
Replied by wzor on topic LinuxCNC + Orange Pi (allwincnc)
I perfectly run on OPi ONE Armbian which is the link above! No problem.)))
- Dolence
5 years 2 months ago #216939
by Dolence
Replied by Dolence on topic LinuxCNC + Orange Pi (allwincnc)
By run you mean you can open an ngc file and run it from the start to finish or just manually move the axis?
- envyvan
- Thank you received: 3
5 years 2 months ago - 5 years 2 months ago #216946
by envyvan
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
Hi Forks,
I upload the Image clone from what I currently using to below
Feel free to try it if you need it.
drive.google.com/file/d/1D3RlYBO9vscBJYZ...1f3/view?usp=sharing
I did change the setting below:
Set the CPU speed to max
Axis gui already been modify to suit the 1024 X 700 touch screen by using the method below:
forum.linuxcnc.org/21-axis/38188-solved-...screen-w-usercommand
Try to install GPU driver has been replace by the method below, but seem like not working well, system still using the software acceleration.
forum.armbian.com/topic/1420-opengl-on-m...api-orangepi-pc-etc/
linux-sunxi.org/Mali_binary_driver#Device_permission
linux-sunxi.org/Xorg#fbturbo_driver
linux-sunxi.org/User:Rellla/Armbian
Notice Issue:
setp arisc.gpio.PG6-pull -1 # pull down PG6 to the GND not fouction correctly.
I can't pull down the input pin for ENCODER which is PG6 AND PG7, so the ENCODER would keep counting when the program start.
If that cause troble to you, remove the parameter from the .HAL file.
O pen browser will lead to realtime error.
Notice Issue:
Last edit: 5 years 2 months ago by envyvan. Reason: upload my ISO and attached the change list.
- Bari
- Thank you received: 234
5 years 2 months ago - 5 years 2 months ago #216947
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Not asking anyone in particular BUT can you post your config files if you are having issues?
.INI and .HAL
Open loop stepping real time errors are all about bad configuration files since there is no closed loop.
Just FYI, the Allwinner devices with the current u-boot have difficulty keeping low latency along with running memory intensive apps such as a browser. The latency test may stay under 70,000 when just running LCNC, but jump to well over 100K when a browser is started. Let us know if you get the real time following errors when you are running LCNC on its own or when you start up other applications such as a browser.
.INI and .HAL
Last edit: 5 years 2 months ago by Bari. Reason: more info
The following user(s) said Thank You: tjtr33
- Cncninja
5 years 2 months ago #216950
by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
isolcpus, cpu=idle, max freq locked, governor=performance. runs without errors but slower than before takes a minute to open a file in Axis before maybe 15 sec. runs chunks unless i click on dro mode... no problem for me just wonder why the load times are x4 now. but it runs with no errors.
- envyvan
5 years 2 months ago #216952
by envyvan
isolcpus, cpu=idle, That mean you set to only use one of your cpu core, other 3 just doing nothing.
I'm not sure "isolcpus, cpu=idle" on this project is a good idea, If there's not anything connent to the base-thread, Why we still need to care about the latency for base-thread?
You will lose much of cpu power that already being weak.
Time to create page: 0.456 seconds
