- Thank you received: 3
LinuxCNC + Orange Pi (allwincnc)
- envyvan
5 years 2 months ago #217197
by envyvan
I try to set like below, which I found it here:
en.opensuse.org/ARM_Mali_GPU
Section "ServerFlags"
Option "AutoAddGPU" "off"
Option "Debug" "dmabuf_capable"
EndSection
Section "OutputClass"
Identifier "Lima"
MatchDriver "sun4i-drm"
Driver "modesetting"
Option "PrimaryGPU" "true"
EndSection
But they won't work, the xface just get kill.
Replied by envyvan on topic LinuxCNC + Orange Pi (allwincnc)
No, I didn't.Did you turn on the hardware accel in GNU to glamor if not it still uses software
EndSection
Identifier "Lima"
EndSection
- cakeslob
- Thank you received: 280
5 years 2 months ago #217266
by cakeslob
for like 5 min im staring at that thinking "how uncanny, thats exactly like mine, even the max spindle speed it the same....how is it so the same?"
Replied by cakeslob on topic LinuxCNC + Orange Pi (allwincnc)
- envyvan
5 years 2 months ago - 5 years 2 months ago #217287
by envyvan
Hi Cakeslob,
Yes, I just grab them from you posts below.
forum.linuxcnc.org/21-axis/38188-solved-...screen-w-usercommand
I just add the jog select at pyvcp.
Hi Forks,
I also try to play with Touchy GUI and some addtional function.
Somehow, Gpu can only support OpenGL ES, which is not the full part of the OpenGL. So we still need to disable all the effect of Xfce.
If we olny runing Touchy, CPU usage would be less then 40%, which is similar to AXIS.
But if you also want Ngcgui, CPU usage will be up to 85%, under this condition Glxgears still runing in 60FPS.|
And so far, I diden't get any error report back.
Hi Forks,
Last edit: 5 years 2 months ago by envyvan.
- taylorcmq
5 years 2 months ago #217334
by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
how is the servo threads latency, here I am getting high latency errors, with your previous image!
- Bari
- Thank you received: 234
5 years 2 months ago - 5 years 2 months ago #217338
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
@ taylorcmq
Thank you.
Please post the actual error and what you were running at the time, e.g. which latency test, LinuxCNC, etc.here I am getting high latency errors,
Who is "yours" and by previous do you mean the one right before the very latest or something else?with your previous image!
Thank you.
Last edit: 5 years 2 months ago by Bari.
- envyvan
5 years 2 months ago #217350
by envyvan
First of all. My Image is Clone from my SD card. I think It would only work on the board with some SOC Board which is Orange Pi PC.
If you were using other board, I think it will lead to some issue.
In that case, you will need to find the Armbian Image for you board first, But you can't use the Image newer than Armbian_21.05.1 with Linux kernel v5.10.34.
Set it up, and do the Install bash. Then do some tuning for you system.
HI Taylorcmg,how is the servo threads latency, here I am getting high latency errors, with your previous image!
Time to create page: 0.168 seconds
