LinuxCNC + Orange Pi (allwincnc)
5 years 1 month ago #220839 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Will the 3.3v GPIO be able to work with this or will I need to build a hat with logic level converters to be able to use it?
Depends on the optos and the series resistors used in front or behind them. Try it and measure.
5 years 1 month ago #220840 by Bari
Since I broke my leg last Saturday and needed something to do to occupy my time
Sorry to hear. Not fun. You might want to wait a few weeks before starting this. Save it for when you are really bored, run out of movies, TV to watch and books to read  :)
5 years 1 month ago #220841 by rollfree
Replied by rollfree on topic LinuxCNC + Orange Pi (allwincnc)
I guess I can test this as well, but figured someone probably knows off the bat.
My machine currently has a parallel port breakout board like this one  www.amazon.com/DollaTek-Breakout-Optical...id=1631818031&sr=8-4
My intent is to retain the parallel port breakout board and construct a cable to interface the GPIO on the OPi to the PP BOB. So the question becomes: Will the 3.3v GPIO be able to work with this or will I need to build a hat with logic level converters to be able to use it?
74HC (not 74HCT) circuits are usually used on these boards. These allow 2-6V power supply. So you can power the board from 3.3V instead of 5V.
The voltage levels on outputs will be probably enough for connected driver.
And on inputs will be 3.3V levels, so OPi will be happy.
Only for relay will be supply 3.3V probably too low.
5 years 1 month ago #220913 by 109jb
Replied by 109jb on topic LinuxCNC + Orange Pi (allwincnc)
Thanks again.
In regard to the BOB, I've decided to make up a hat for level shifting. Reason is because the power input to that BOB is 12V currently and it uses a 5V on-board regulator to supply the 74HC chips, so I'd have to tap into the board to supply less voltage to those chips. Also it has an on-board PWM to analog 0-10V output for controlling a spindle. I think at some point i will hook that up to my VFD for spindle control. So, seems the easiest is to just do the level shifter hat since I already have everything to do that. Thanks for the info though.
The Orange Pi One board arrived yesterday and I had a heck of a time even getting the canned Armbian image installed. Turned out that my favorite USB carb reader for micro SDs crapped out. Took a couple hours of dorking around to figure that out. Once I got my other one all went well and Armbian buster is installed. Now I have to figure out how to get an internet connection to the OPi. My router is just too far away and I don't have a long enough ethernet cable so I'm thinking I can share the connection to my laptop using a USB to Ethernet adapter. I ordered the USB-Ethernet adapter and it should get here tomorrow so will try then. I am documenting my adventure and once I get everything situated I plan to make an image of the SD that can hopefully just be installed on a Orange Pi One board like mine for those who want a sort of plug and play solution.
Thanks again to all. I'll keep my progress updated
5 years 1 month ago #220925 by 109jb
Found out I am mistaken about my BOB and have questions. Didn't want to take this thread on a tangent, so posted my question in the thread I started here: forum.linuxcnc.org/18-computer/43570-con...-get?start=20#220924
5 years 1 month ago #220926 by Bari
Just about everyones config.ini file will be different as well as their .hal file.
U-boot and the kernel should just have the cpu core speed governor locked to ONE clock speed no matter what. Choose to not use a heat sink, too bad. And spend and extra dollar or two for a proper power supply.
Time to create page: 0.251 seconds
