LinuxCNC + Orange Pi (allwincnc)
5 years 1 month ago #220931 by 109jb
Replied by 109jb on topic LinuxCNC + Orange Pi (allwincnc)
Thanks. I did install a heat sink. Fan will be installed soon too. Power supply right now is a 10A bench power supply set to 5.1V. A 5V 2.5A power supply with Orange Pi specific connector is on the way.
For the image, I understand that there will be changes required from my configuration, but I also think there may be many that would like to try this project but may be intimidated. I intend a basic starting point with detailed step by step instructions for editing the configuration files to achieve a basic machine setup. I figure I'm going to image it anyway for my own backup purposes and would make it available on my google drive for anyone interested.
The following user(s) said Thank You: Bari, wzor
5 years 1 month ago #221031 by 109jb
So while waiting for stuff to come in I have been thinking more. One thing I have always wanted to do is to CNC my small 9x20 lathe. But if I CNC the lathe I would absolutely want to have a spindle encoder so that I could do spindle sync to do threading operations. Is there anything on the Orange Pi implementation of LinuxCNC that would prevent spindle synchronized motion for threading, either on a lathe, or maybe also on a mill for tapping?
Also, for the lathe, I would like to put a pair of hand wheel encoders on, one for manually controlling the X axis and one for the Z axis. This would enable using the lathe like a pseudo manual lathe as well as for CNC. Would this also be possible?
Thanks.
5 years 1 month ago #221035 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
Encoder feedback for closed loop was worked on. I have not tried it yet to see how far along he got. The only problem might be how fast can position info be passed back to the big ARM cores for closing the loop for spindle synchronization.
It should not be a problem unless you are trying to hand turn and run a program at the same time with closed loop. Not that you would. In manual mode the drives are disabled so you can freely turn the hand wheels.
5 years 1 month ago - 5 years 1 month ago #221084 by 109jb
EDIT:  I found what I needed in some of the documentation and in this loooong thread.
BTW:  I think you misunderstood what I was talking about. My lather will not have any direct mechanical connection to handwheels.  I intend to use handwheel encoders, manual pulse generators, or whatever you want to call them to simulate the manual cranks on a lathe. They would be connected electronically to LinuxCNC and used in jog mode like the manual cranks would, but all motion would be done by LinuxCNC driving the stepper motors.
Last edit: 5 years 1 month ago by 109jb.
5 years 1 month ago #221198 by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
I think this project is dead, it was never finished. I would look more at the STM build with Remora. I have an H3 2gb board just sitting if this does ever start back up.
5 years 1 month ago #221206 by Bari
Have you noticed that 109jb is trying to work on it and fix it?
Time to create page: 0.524 seconds
