- Thank you received: 12
LinuxCNC + Orange Pi (allwincnc)
- twoflowers
- Visitor
6 years 1 month ago #183748
by twoflowers
Replied by twoflowers on topic LinuxCNC + Orange Pi
I'm not so lucky
The older RT kernel does not agree with my new orangepi PC one plus. USB is not powered, ergo all USB devices don't work. The lates kernel from armbian works flawless. Network works, so this thing still can work as a networked controlle ...
But the installer worked without problems on OrangePi Zero LTS (USB is working)
The older RT kernel does not agree with my new orangepi PC one plus. USB is not powered, ergo all USB devices don't work. The lates kernel from armbian works flawless. Network works, so this thing still can work as a networked controlle ...But the installer worked without problems on OrangePi Zero LTS (USB is working)
- fery15sty
6 years 1 month ago - 6 years 1 month ago #183800
by fery15sty
Replied by fery15sty on topic LinuxCNC + Orange Pi
I've tried multiaxis (5axis) in my armbian, and it works fine. but some menus is not working..
in joint mode, joint 1 and joint 5 cannot manually jog
and
in word mode, axis c cannot manually jog
how to fix this problem?
and
Last edit: 6 years 1 month ago by fery15sty.
- beardbird
6 years 1 month ago #184400
by beardbird
Replied by beardbird on topic LinuxCNC + Orange Pi
Is there any progress on the skipping step issue? Is it suggested to not run my machine with an Orange Pi until it is resolved?
- pinder
- Thank you received: 128
6 years 1 month ago - 6 years 1 month ago #184462
by pinder
Replied by pinder on topic LinuxCNC + Orange Pi
Huge thanks to MX_master,
I have been following the cnc-club.ru thread for a long time.
Now I have some boards to test.
CNC32.ru seems like not working.
Can someone point me in right direction for installing.
Update: Found quick start guide.
orangecnc.gitlab.io/quick-start.html
It should have been on the first post.
Last edit: 6 years 1 month ago by pinder.
- MX_Master
- Thank you received: 48
6 years 4 weeks ago #184537
by MX_Master
There's no funding for this project.
There's no any help from other people to keep this project up-to-date.
Too many problems to use build-in RISC core with new kernels and u-boot.
Sorry
Replied by MX_Master on topic LinuxCNC + Orange Pi
There's no time to do that.beardbird wrote: Is there any progress on the skipping step issue? Is it suggested to not run my machine with an Orange Pi until it is resolved?
Sorry
The following user(s) said Thank You: twoflowers, pinder, beardbird
- twoflowers
- Visitor
6 years 4 weeks ago #184542
by twoflowers
That's a pitty. I tried to compile a newer version of the kernel with RT, but failed miserably. Looks like the ARM ecosystem apart from RPi 4 is not a save bet for developers. I remember Xenomai on RPi2 was quite impressive compared to RT on Rpi3. but the project did not get any traction and the images are not to be found any more.
Anyway, thank you for carrying that project so far as you did. Your build works quite good on the OrangePi Zero (LTS), which is amazing for that small unit.
Time to create page: 0.769 seconds
