Installing LinuxCNC On HP T610 Thin Client
- seuchato
- Thank you received: 126
04 Jan 2022 18:21 #230814
by seuchato
I have run several tests using graphical and text mode latency test. I am pretty sure, they are different. I just had a short glimpse on your scripts. I feel, when getting time for it, I might get a punch on improving my attempt to propose a - kinda - standardized testing environment for hardware and latency. Would you mind me talking part of your scripts into my effort?
Or even better: Join efforts?
Greez
chris
Replied by seuchato on topic Installing LinuxCNC On HP T610 Thin Client
JScripts that I used/adjusted for this test.
This includes the hog cpu script and the linuxcnc wrapper script that needs to be used. This wrapper starts linuxcnc on core 2 then moves the UI task to Core 1. This needed to ensure a balance of UI responsiveness while the RT tasks own Core 2.
Cpu hog on core 2 ensures clock speeds are maxed while linuxcnc is running. A quirk of this architecture seems to be that maxing core 2 also maxes core 1. But the opposite is not true. An alternative setup is to use idle=poll on the kernwl boot. In which case cou hog is not needed. However the cpu will run hot. I was seeing 70C which is deemed “hot” by this cpu with 100C as critical.
The advantage of cpu hog is if you stop lcnc the wrapper kills hog and the cpu will start to cool.
You will also see from the h/w test file that kernel 4.19 was used. I also tests with 4.9.0-13 and noticed that clock speeds seemed to be maxed irrespective of using idle=poll on kernel boot or not.
Cheers - J
Greez
chris
- Joco
- Thank you received: 327
04 Jan 2022 21:07 #230822
by Joco
Replied by Joco on topic Installing LinuxCNC On HP T610 Thin Client
This is originally a tommylight script from:
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
So if you are looking for the latest and want to work improvements etc suggest you work there.
The other scripts I had in the mix are offered as is where is.
You want to use/improve them, knock your socks off.
- Thank you received: 7505
04 Jan 2022 21:38 #230824
Replied by tommylight on topic Installing LinuxCNC On HP T610 Thin Client
That is his script, not mine !This is originally a tommylight script from:
- Joco
05 Jan 2022 01:25 #230839
by Joco
Ah. Wasn't sure from the way the start of the thread was written. So essentially .. have at it!
- Joco
05 Jan 2022 01:42 #230840
by Joco
For interest I installed Bullseye and then MX21 on this machine. Neither will show the onboard NIC. I didn't bother going any further as I basically had a "F you Debian" moment. How stupid is an OS that sees the onboard NIC just fine during install, even uses it to update latest packages and then when boots post install refuses to see said NIC anymore. Ok - rant off. Now I remember why I went to Arch Linux on these for py3.
If anyone has some magic sauce on how to make it see the onboard NIC under Bullseye or derivative I would love to know.
Cheers.
Cheers.
05 Jan 2022 02:33 #230841
You can always try the non free version of Debian:
cdimage.debian.org/cdimage/unofficial/no...ee/amd64/iso-hybrid/
Choose what desktop you like, then see this:
forum.linuxcnc.org/9-installing-linuxcnc...cnc-2-8-on-debian-11
Then since you use QtPyVCP a lot, see here:
www.qtpyvcp.com/install/bullseye.html
- Thank you received: 4155
05 Jan 2022 03:14 #230842
Replied by rodw on topic Installing LinuxCNC On HP T610 Thin Client
Don't mind me laughing Tommy. Joco wrote those instructions!Then since you use QtPyVCP a lot, see here:
- ALittleOffTheRails
- Visitor
05 Jan 2022 03:27 - 05 Jan 2022 03:36 #230844
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Installing LinuxCNC On HP T610 Thin Client
According to modinfo tg3 supports that NIC.
One thing you may want to check after boot is to check if the kernel is recognising the NIC and if there is any missing firmware.
firmware: tigon/tg3_tso5.bin
firmware: tigon/tg3_tso.bin
firmware: tigon/tg3.bin
If you just want the firmware these may just be the ones:
anduin.linuxfromscratch.org/sources/linux-firmware/tigon/
Apparently they should live here:
/lib/firmware/tigon/
If you want to leave it for a couple of days mine should be arriving by post and I can have a quick look to see what's happening.
Wasn't dave having no luck with Bullseye ?
Last edit: 05 Jan 2022 03:36 by ALittleOffTheRails.
- Joco
05 Jan 2022 03:39 #230846
by Joco
On a hunch I did an apt update/upgrade on MX21 and rebooted. tg3 (which was loading before) is now recognising the nic. Didn't get that joy on Bullseye (non free xfce version). But I will "give it another crack" just to prove to myself I haven't missed the point.
Cheers - J.
Cheers - J.
05 Jan 2022 03:40 #230847
I do not mind at all, i do mind that i did not know that, so that is another reason to laugh !
But i did try those instructions with a bit of shortcut as i downloaded BigJT's precompiled LinuxCNC, and it all works perfectly well.
Just in case:
-download nonfree Debian 11, install
-update, upgrade, install RT kernel
-download JT's deb's, install with gdebi
--after this QtPlasmaC works
-install QtPyVCP stuff
Just in case:
Time to create page: 0.497 seconds
