Parallell Port PCI & PCIe Add In Card Info Thread
16 Jun 2021 07:07 #212181 by phillc54
No difference Rob, it still runs a parport config fine.
garage:~ $ sudo dmesg -C
garage:~ $ sudo modprobe parport_pc io-0xdc00 irq=10
garage:~ $ ~/linuxcnc-dev/scripts/linuxcnc ~/linuxcnc/configs/mill/mill.ini
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/phill/linuxcnc/configs/mill'
Machine configuration file is 'mill.ini.expanded'
Starting LinuxCNC...
Found file(REL): ./mill.hal
Waiting for component 'trivkins' to become ready.......Waited 3 seconds for master.  giving up.
.Note: Using POSIX realtime
config string 'dc00 out'
Linux parallel port @56320 not found
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
16 Jun 2021 07:26 #212182 by BeagleBrainz
Replied by BeagleBrainz on topic Parallell Port PCI & PCIe Add In Card Info Thread
No output from the second dmesg ?
16 Jun 2021 08:03 - 16 Jun 2021 08:04 #212184 by phillc54
None at all, that is copy/paste from the screen.
An interesting thing is that I am playing around with a Mesa 7i90 I bought a few years ago and have never used.
I can see the 7i90 from the hm2_7i90 driver and also mesaflash from the first Oxford chipped card but not from the MosChip chipped card. Yet a LinuxCN parport config works fine for both cards.
Edit: Shoot I just noticed a typo in my modprobe command. I will try again...
Last edit: 16 Jun 2021 08:04 by phillc54.
16 Jun 2021 08:12 #212185 by phillc54
Still the same, no output from the second dmesg.
I also did a verbose on modprobe but nothing there as well...
  • BeagleBrainz
  • Visitor
  • Visitor
16 Jun 2021 09:37 - 16 Jun 2021 09:39 #212188 by BeagleBrainz
Interesting
Laptop without PP, choosing an arbitrary empty address
First run of Linuxcnc is without loading ppdev
2nd & 3rd runs of Linuxcnc is after loading ppdev
None of the 3 runs gave the "port not found" message.
rmurphy@thinkPad-t530:~$ sudo modprobe parport_pc io=0xdc00
rmurphy@thinkPad-t530:~$ dmesg
[43175.578001] parport 0xdc00 (WARNING): CTR: wrote 0x0c, read 0xff
[43175.578005] parport 0xdc00 (WARNING): DATA: wrote 0xaa, read 0xff
[43175.578006] parport 0xdc00: You gave this address, but there is probably no parallel port there!
[43175.578015] parport0: PC-style at 0xdc00, irq -20544 [PCSPP,TRISTATE]
[43175.578018] parport0: irq -20544 in use, resorting to polled operation
rmurphy@thinkPad-t530:~$ linuxcnc
LINUXCNC - 2.8.1
Machine configuration directory is '/home/rmurphy/linuxcnc/configs/by_interface.parport.stepper-1'
Machine configuration file is 'stepper_mm.ini'
Found file(lib): /usr/share/linuxcnc/hallib/core_stepper.hal
Found file(REL): ./standard_pinout.hal
config string '0xdc00'
open(/dev/parport0): No such file or directory
hal_parport: rtapi_app_main: No such file or directory (-2)
./standard_pinout.hal:5: waitpid failed /usr/bin/rtapi_app hal_parport
./standard_pinout.hal:5: /usr/bin/rtapi_app exited without becoming ready
./standard_pinout.hal:5: insmod for hal_parport failed, returned -1
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/rmurphy/linuxcnc_debug.txt
and
    /home/rmurphy/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
rmurphy@thinkPad-t530:~$ sudo modprobe ppdev
LINUXCNC - 2.8.1
note: MAXV     max: 30.480 units/sec 1828.800 units/min
note: LJOG     max: 30.480 units/sec 1828.800 units/min
note: LJOG default: 0.424 units/sec 25.440 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
task: 596 cycles, min=0.000061, max=0.023330, avg=0.009850, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LINUXCNC - 2.8.1
config string '0'
task: 426 cycles, min=0.000046, max=0.018297, avg=0.009764, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Last edit: 16 Jun 2021 09:39 by BeagleBrainz.
16 Jun 2021 11:46 #212192 by phillc54
Strange stuff, I will give it a shot tomorrow with the parport removed.
  • BeagleBrainz
  • Visitor
  • Visitor
16 Jun 2021 12:25 - 16 Jun 2021 12:26 #212195 by BeagleBrainz
If you can reboot
Then run with the PP still installed
sudo dmesg -C
sudo modprobe parport_pc io=0xdc00 irq=10
sudo dmesg
ls /dev/parport*
sudo modprobe ppdev
ls /dev/parport*
Now I'm thinking all this should create a /dev/parport0 entry.
Then instead of using loadrt hal_parport cfg="0xdc00 out" you should be able use loadrt hal_parport cfg="0 out"
Last edit: 16 Jun 2021 12:26 by BeagleBrainz.
17 Jun 2021 00:30 #212243 by phillc54
With the PP installed:
garage:~ $ sudo modprobe parport_pc io=0xdc00 irq=10
garage:~ $ ls /dev/parport*
ls: cannot access '/dev/parport*': No such file or directory
garage:~ $ sudo modprobe ppdev
garage:~ $
Without the PP installed:
garage:~ $ dmesg
garage:~ $
  • BeagleBrainz
  • Visitor
  • Visitor
17 Jun 2021 01:10 #212245 by BeagleBrainz
What Distro are you using ?
It's strange that there is no output after dmesg.
Did you reboot before running these commands ?
17 Jun 2021 01:16 #212246 by phillc54
MX-19.4, a Buster derivative
I agree
I surely did.
Time to create page: 1.163 seconds
