- zmrdko
- Thank you received: 49
10 Apr 2023 08:18 #268745
by zmrdko
Replied by zmrdko on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thanks! I set Pgain to 10, 100 and even 200. It helped, but I am still getting 0.02 mm error now and then. Like 10 jogs are accurate and 1 jog is 0.02 off.
- meister
- Thank you received: 419
10 Apr 2023 08:20 - 10 Apr 2023 11:22 #268746
by meister
Replied by meister on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I think,
there is absolutely no reason to run the normal IO's in an interrupt,
but there are many reasons to reduce the code inside interrupt's.
My Changes:
github.com/multigcs/Remora-RT1052/tree/l...jitter_test/firmware
i removed also the __disable_irq part and add some kind of double buffer
My Changes:
Last edit: 10 Apr 2023 11:22 by meister.
- meister
10 Apr 2023 09:17 #268748
by meister
- scotta
- Thank you received: 486
10 Apr 2023 22:26 #268787
by scotta
You've added a rxDataCopy as a double buffer but it's never used in this way in your code.
The disabling of the irq during data copying was to Cakeslob's point, a fix for a more serious issue when data was corrupted during the infrequent but possible scenario where data was being copied and the thread was triggered.
Did you inform LinuxCNC of your base thread frequency change?
Remora has been running "threads" in interrupt context since its inception by design. The RT1052 version of the firmware exposes the underlying design as it's a C version of the code vs the C++ version which treats the threads (ISR) as an object which modules can be added to.I think,
My Changes:
- meister
11 Apr 2023 07:42 #268807
by meister
the rxDataCopy is used in the baseThread and will be updated on a save place right after receiving is complete done, triggerd by rxDataFlag.
Ok, will not waste your time anymore, my changes works for me, i am happy, thanks for your work !
greetings, Olli
greetings, Olli
- scotta
11 Apr 2023 22:39 #268850
by scotta
Sorry, please don't take my questions the wrong way, I'm just trying to understand your changes. Where is rxDataCopy being filled with the incoming packet? in the UDP callback the data is being put straight into rxData..?
github.com/multigcs/Remora-RT1052/blob/5...urce/ethernet.c#L133
- cakeslob
- Thank you received: 275
12 Apr 2023 00:51 #268860
by cakeslob
Do the same thing, but with deadband
The following user(s) said Thank You: zmrdko
- meister
12 Apr 2023 07:13 #268873
by meister
source/baseThread.c:
but i think its better to move this part to the end of the makeSteps() function
void makeSteps()
static int8_t i;
static int32_t stepNow;
if (rxDataFlag == 1) {
rxDataFlag = 0;
memcpy(rxDataCopy.rxBuffer, rxData.rxBuffer, BUFFER_SIZE);
....but i think its better to move this part to the end of the makeSteps() function
- zmrdko
12 Apr 2023 19:57 #268929
by zmrdko
Thanks Scott. It was set to 0, but I changed it to 0.0001 and it seems to work fine now. I have now issue with motor accuracy. The scale is set to 160 and I have set jumpers on JMC ihsv57 motor to 800 steps per rotation so 5mm jog should be exactly one full circle. However its a little less than that. After few 5mm jogs its obvious. So do I have problem with step pulse lenghts?
- meister
12 Apr 2023 20:08 - 12 Apr 2023 20:13 #268931
by meister
You can try to move very, very slow and check the distance if its better.
If you have a rt1052 based board:
and if it's not too much trouble, you could try my version: github.com/multigcs/Remora-RT1052/tree/l...jitter_test/firmware
its compiled for the EC300 V5
I would be interested to know if it makes a difference
Last edit: 12 Apr 2023 20:13 by meister.
Time to create page: 0.507 seconds
