Hi, i have a new EC500 board (see attached picture from chip) and trying to use it with linuxcnc and remora.
After some troubles to flash it with a converted ST-Link-V2, it seems to be that i successfully flashed it to remora with the raspberry pico under windows. See output below: (Under Linux (standard LinuxCNC build), I cannot establish a connection with the Pico CMSIS-DAP und linux.
PS C:\Users\...\Desktop> pyocd flash ./remora-rt1052-3.1.2.bin --target mimxrt1050_quadspi -v
0000693 I Target type is mimxrt1050_quadspi [board]
0000726 I DP IDR = 0x0bd11477 (v1 MINDP rev0) [dap]
0000749 I AHB-AP#0 IDR = 0x04770041 (AHB-AP var4 rev0) [discovery]
0000760 I AHB-AP#0 Class 0x1 ROM table #0 @ 0xe00fd000 (designer=00e:NXP part=88c) [rom_table]
0000766 I [0]<e00fe000:ROM class=1 designer=43b:Arm part=4c8> [rom_table]
0000766 I AHB-AP#0 Class 0x1 ROM table #1 @ 0xe00fe000 (designer=43b:Arm part=4c8) [rom_table]
0000771 I [0]<e00ff000:ROM class=1 designer=43b:Arm part=4c7> [rom_table]
0000772 I AHB-AP#0 Class 0x1 ROM table #2 @ 0xe00ff000 (designer=43b:Arm part=4c7) [rom_table]
0000780 I [0]<e000e000:SCS v7-M class=14 designer=43b:Arm part=00c> [rom_table]
0000784 I [1]<e0001000:DWT v7-M class=14 designer=43b:Arm part=002> [rom_table]
0000787 I [2]<e0002000:FPB v7-M class=14 designer=43b:Arm part=00e> [rom_table]
0000790 I [3]<e0000000:ITM v7-M class=14 designer=43b:Arm part=001> [rom_table]
0000794 I [1]<e0041000:ETM M7 class=9 designer=43b:Arm part=975 devtype=13 archid=4a13 devid=0:0:0> [rom_table]
0000801 I [2]<e0042000:CTI CS-400 class=9 designer=43b:Arm part=906 devtype=14 archid=0000 devid=40800:0:0> [rom_table]
0000805 I [1]<e0040000:TPIU M7 class=9 designer=43b:Arm part=9a9 devtype=11 archid=0000 devid=ca1:0:0> [rom_table]
0000807 I [2]<e0043000:TSGEN class=15 designer=43b:Arm part=101> [rom_table]
0000811 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0000818 I CPU core #0: Cortex-M7 r1p1, v7.0-M architecture [cortex_m]
0000819 I Extensions: [DSP, FPU, FPU_DP, FPU_V5, MPU] [cortex_m]
0000819 I FPU present: FPv5-D16-M [cortex_m]
0000827 I 4 hardware watchpoints [dwt]
0000831 I 8 hardware breakpoints, 1 literal comparators [fpb]
0000846 I Loading C:\Users\...\Desktop\remora-rt1052-3.1.2.bin [load_cmd]
0000982 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0001028 I IMXRT Boot Device: 0 [target_imxrt]
100%
0031426 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0031428 I IMXRT Boot Device: 0 [target_imxrt]
0031545 I Erased 196608 bytes (3 sectors), programmed 147968 bytes (578 pages), skipped 0 bytes (0 pages) at 4.72 kB/s [loader]
My problem is that although it looks like the flashing worked, I can't establish a connection over the network. Ping 10.10.10.10, no response. I have already tried different ways to configure the manual IP on the linuxCNC pc.Can you please help me? What else can I do? Thank you in advance.
