  • vpomerleau
  • Junior Member
  • Junior Member
1 year 9 months ago #319557 by vpomerleau
Replied by vpomerleau on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi guys! I'm also trying to configure closed loop spindle on my RT1052 EC500. I mounted a Hall Sensor to my spindle and I see it under remora.input.31. I have a motor to spindle ratio of 1.8:1, I used Cakeslob config example with slight modifications. The spindle run but doesn't look closed loop since the rpm is not right but I can vary the speed with the override. I'm sure i'm missing something, do you need to configure the PRUencoder in the config.txt you upload to controller or everything is done in the .ini and .hal file? My mill is a Bridgeport with 2 gears (Low=50-1300 and High=1300-5000). For now I only want to configure closed loop on the high range and i'm gonna do the gearchange later. Any help will be really appreciated.
1 year 9 months ago #319558 by mudrat
Murphy, your picture shows a magnetic encoder, not optical. The Omron e6b2 encoders have 4 different versions, with different voltages and polarity.
If it is a direct copy then your index pulse is on the orange or orange/orange with red stripe depending on version.
1 year 9 months ago - 1 year 9 months ago #319561 by Murphy
@Mudrat, I thought it was noise I was experiencing. But when I took the encoder apart I found it was a magnetic pickup instead of optical. It lost pulses above 200rpm and stopped counting. All omron e6b2 encoders have a dual board with disk inside. This was a single board. Pic below what it's suppose to look like inside(don't know if it genuine or a good copy)
Last edit: 1 year 9 months ago by Murphy.
1 year 9 months ago #319562 by mudrat
What was the part number of the original encoder?
If it was an open collector output, was your pull up resistor to high a value?
Did you look at the pulse train with a scope?
1 year 9 months ago - 1 year 9 months ago #319563 by Murphy
The pulse turning it by hand seemed good. Anything over about 150rpm the pulse was distorted , it was an open collector npn 500ppr
1 year 9 months ago - 1 year 9 months ago #319564 by Murphy
@ vpomerleau, you may have to bypass the opticouplers on the board if it's over 2.5khz. rbobey1989 has a post in this thread about it.
If I ever manage to get mine going. I'll document what I did and what opticouplers to bypass etc
Time to create page: 0.316 seconds
