- Thank you received: 280
- cakeslob
1 year 9 months ago - 1 year 9 months ago #319682
by cakeslob
Ok, and the quill is motorized it looks like? We can figure out the ratio stuff later. lets start by ensuring you get the proper rpm from remora. I think the board is doing a 0-10v analog correct? You should be able to measure the voltage output from the board and verify its outputting correctly.
If I have this correct, when you S5000 M3, it should read 10v.
edit, to do threading, you will need an encoder.
Last edit: 1 year 9 months ago by cakeslob.
- nicnucan
1 year 9 months ago - 1 year 9 months ago #320314
by nicnucan
Replied by nicnucan on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello everyone,I have a question regarding uploading the Remora config, as the config upload runs into a timeout.
To explain: I am using an EC500 board flashed with the latest Remora CPP version. Uploading a new config has worked flawlessly multiple times before, but ever since I switched from Ubuntu Linux to the Debian LinuxCNC ISO, it no longer works and results in a timeout.
Reflashing the EC500 works without any issues. The board can be pinged and used without problems. However, the config upload using upload_config.py does not work.Has anyone encountered this issue before and maybe has a tip for me? I know that I could theoretically compile a modified config into a firmware build, but I would like to get the upload function working again.
Thanks and best regards!
Last edit: 1 year 9 months ago by nicnucan.
- cakeslob
1 year 8 months ago #320376
by cakeslob
I think the majority of us are using a debian of some kind. you are using the latest bullseye image?
raf did a write up on his process for install
forum.linuxcnc.org/18-computer/44828-rem...rd?start=1570#291712
i guess try that first, but if you can run, and ping, and tftpy is working,
the next thing to try would be to doing a fullchip erase on the rt1052, and reloading the firmware and config
i was trying to find the error that produces just now, but i cant find the old posts about it.
- beauxnez
- Thank you received: 10
1 year 8 months ago - 1 year 8 months ago #320769
by beauxnez
Replied by beauxnez on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
1. Convert an ST-Link to a CMSIS-DAP probe by using a a second ST-Link and the ST-Link utility to flash the CMSIS-DAP firmware.
mvdlande.wordpress.com/2015/10/05/cmsis-...ink-v2-mini-adapter/
2. Use pyOCD with the newly flashed CMSIS-DAP probe to flash the firmware to the controller board
python -m pip install -U pyocd
pyocd flash .\remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
github.com/scottalford75/Remora-RT1052-c...ora-rt1052-3.1.3.bin
Hello, I'm coming back to the charge on my RT 1052 card, I'm trying to flash with the CMSIS-DAP firmware but I have an error message the card is not detected?
Last edit: 1 year 8 months ago by beauxnez.
- beauxnez
1 year 8 months ago - 1 year 8 months ago #320784
by beauxnez
I just managed to reverse the 2 stlink keys but it does not appear as maintenance?
youtube.com/shorts/SjhZnoY1864
- scotta
- Thank you received: 489
1 year 8 months ago #320841
by scotta
I think your confusing this with the earlier DAPlink firmware that allowed drag and drop upload.
The CMSIS-DAP-STLINK21.hex firmware converts the STLink into a CMSIS-DAP probe that can be used the MCUxpresso or pyOCD.
Time to create page: 0.258 seconds
