- Thank you received: 10
- beauxnez
1 year 8 months ago - 1 year 8 months ago #321252
by beauxnez
Replied by beauxnez on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
still an error
Debug file information:
Note: Using POSIX realtime
MOTION: num_joints is 33, must be between 1 and 16
motmod: rtapi_app_main: Operation not permitted (-1)
./NVEM.hal:5: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:5: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:5: insmod for motmod failed, returned -1
10762
Stopping realtime threads
Unloading hal components
Last edit: 1 year 8 months ago by beauxnez.
- beauxnez
1 year 8 months ago - 1 year 8 months ago #321253
by beauxnez
- beauxnez
1 year 8 months ago - 1 year 8 months ago #321261
by beauxnez
the pin number on the config.txt file is "P4_17"
"Thread": "Servo",
"Type": "Digital Pin",
"Comment": "XIN",
"Pin": "P4_17",
"Mode": "Input",
"Data Bit": 17,
"Invert": "True"
I have to write like this in the .hal file?
# ---X Axis Inputs---
# X Home Prox
net XHome joint.0.home-sw-in <= remora.input.17
"Thread": "Servo",
"Comment": "XIN",
"Pin": "P4_17",
"Mode": "Input",
"Data Bit": 17,
"Invert": "True"
# X Home Prox
- cakeslob
- Thank you received: 280
1 year 8 months ago #321318
by cakeslob
yeah, did you fix the other 2? the first one is you didnt install the nvmpg component, and the second one is the halfile for that usb pendant isnt present
but yes thats how you connect the x thing probably
- beauxnez
1 year 8 months ago - 1 year 8 months ago #321368
by beauxnez
I installed the nvmpg component but I still have the same error with the command
sudo halcompile --install nvmpg.c.
I have a Linux Mint LMDE 6 Faye version, it may be too old?
- cakeslob
1 year 8 months ago #321372
by cakeslob
I think I misread that first error,
remove the xhc-whb04b-6.hal
[HAL]
HALFILE = NVEM.hal
HALFILE = qtplasmac_comp.hal
HALFILE = xhc-whb04b-6.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal.
Time to create page: 0.310 seconds
