1 year 8 months ago #321500 by cakeslob
Im confused --
RPI5 - linuxcnc 2.9.2 (from iso on linuxcnc download page)  I get same results on linux on a x86 system
I have a Novusun V5 that I loaded with ....Remora-RT1052-cpp/blob/main/Firmware/remora-rt1052-3.1.3.bin
I've run halcompile on remora-nv in Remora-NVEM-main/LinuxCNC/Components/Remora-nv
Hey, can you explain the process that lead you to download the firmware from one repo, but install the component from another? I am trying to identify what is causing people to continue to make this error
remora-docs.readthedocs.io/en/latest/har...Ethernet/rt1052.html
1 year 8 months ago - 1 year 8 months ago #321507 by beauxnez
has anyone made qtplasmac work with a NVEM card?
i modified the .hal file with
[code]Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7 Machine configuration directory is '/home/manu/linuxcnc/configs/NVEM' Machine configuration file is 'NVEM.ini' INIFILE=/home/manu/linuxcnc/configs/NVEM/NVEM.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TPMOD= HOMEMOD= TASK=milltask HALUI=halui DISPLAY=qtvcp qtplasmac COORDINATES=X Y Z KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./NVEM.hal Found file(lib): /usr/share/linuxcnc/hallib/qtplasmac_comp.hal Found file(REL): ./custom.hal Starting TASK program: milltask Starting DISPLAY program: qtvcp No section: 'SHUTDOWN_OPTIONS' Adding section SHUTDOWN_OPTIONS Shutting down and cleaning up LinuxCNC... Running HAL shutdown script task: 809 cycles, min=0.000007, max=0.010275, avg=0.009722, 0 latency excursions (> 10x expected cycle time of 0.010000s) Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime [QTvcp.QTVCP.QT_MAKEGUI][[31mERROR[0m]  Trouble looking for handlers in 'qtplasmac_handler': (qt_makegui.py:330) Traceback (most recent call last):   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 308, in _load_handlers     objlist = h(halcomp, widgets, self.PATHS)  # this sets the handler class signature               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 6000, in get_handlers     return [HandlerClass(halcomp, widgets, paths)]             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__     float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60     ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ TypeError: float() argument must be a string or a real number, not 'NoneType' [QTvcp][[41mCRITICAL[0m]  Aborted from Error Dialog  Qtvcp encountered an error.  The following information may be useful in troubleshooting: LinuxCNC Version  : 2.9.0~pre1+git20230208.f1270d6ed7 Traceback (most recent call last):   File "/usr/bin/qtvcp", line 508, in <module>     _qtvcp = QTVCP()              ^^^^^^^   File "/usr/bin/qtvcp", line 251, in __init__     window.load_extension(opts.usermod)   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 265, in load_extension     methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 308, in _load_handlers     objlist = h(halcomp, widgets, self.PATHS)  # this sets the handler class signature               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 6000, in get_handlers     return [HandlerClass(halcomp, widgets, paths)]             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__     float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60     ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ TypeError: float() argument must be a string or a real number, not 'NoneType'  (qtvcp:464) 15446 15483 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
[/code]
Last edit: 1 year 8 months ago by beauxnez.
1 year 8 months ago - 1 year 8 months ago #321518 by LeslieTroyer
Replied by LeslieTroyer on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
of the repositories that looked "hopeful"
Remora-main, and Remora-RT2052-cpp-Main had remora-the-3.0.c
both the same -- neither worked (forgot to incclude that)
and the one listed which also didn't work -- (same error)
I think maybe the 3.0 one I worried was specifically related to the EC500 (all the remora-??? directories under LinuxCNC appear from filenames to be ec500 based
i did hook up a LA1010 to the rs232 port and saw lots of data being transmitted but not much was readable - i then connected the screen that come with the NVEM to the serial port - and now my device its totally unresponsive on the serial port and ethernet port ...
Last edit: 1 year 8 months ago by LeslieTroyer.
1 year 8 months ago #321556 by cakeslob
If your board has the RT1052, refer to the page I linked to, and only install the components/firmware/configurations referred to in the documents. The linuxcnc .hal file configuration doesnt matter if its EC500 or NVEM. The config.txt is important to match with the board.
1 year 8 months ago #321559 by cakeslob
  File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__     float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60   File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__     float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60
If anyone had a qtplasmac config for the NVEM, they would have ended our suffering 2 pages ago.
its probably this, i think the THC probably uses external offsets.
add this line and report back
github.com/rodw-au/showstopper/blob/master/my_Plasma.ini#L226
or the next time an error pops up, you can try and trace it out, using all those other plasmac examples I posted before, or by referring to rods config I just listed, otherwise this will be a very long process.
1 year 8 months ago - 1 year 8 months ago #321569 by beauxnez
well I'm saved because I see that you are starting to lose patience,
 but I'm not fired because I have the emergency stop that does not unlock but I think I know where it comes from,
 for info I went to debian 12 with linuxcnc 2.9.4 while I was on mint with linuxcnc 2.9.0
Many thanks to you I will post my file and the 2 to 3 things that I know
Time to create page: 0.511 seconds
