3 years 5 months ago #271601 by frayja2002
I was wondering if someone could put their 2c worth on this.
I have received a EC300 board & tried to flash it....Failed.
I get an error (posted below) I have searched the internet & got no further understanding of what the problem is.
I have tried to re-flash my EC500 board which previously worked. Now failing.
I have tried a different stlink module (checked the wiring is correct) Same error.
I cannot get these stlink things to work or they work for five min & pack it in for no reason.
There has to be a better way.
Alex
3 years 5 months ago #271607 by meister
i sometimes have to press the internal boot button to be able to flash
3 years 5 months ago #271633 by scotta
Looks like you are using an unmodified ST-Link that has not been reflashed as a CMSIS-DAP correct?
Also, I thought pyOCD needed python 3.7 or greater?
3 years 5 months ago - 3 years 5 months ago #272609 by rbobey1989
hello everyone here, first of all congratulate Scott again for his great work, I've been looking at some cheap boards on aliexpress for a few days, some time ago I had ordered some bluepill cards on aliexpress and to my surprise they arrived with a somewhat unknown chip CH32F103C8T6 (STM32 copy), after some research, not bad, the Chinese company that produces them WCH also produces other chips, one in particular that has caught my attention is the CH32V307, Device Features , especially built-in ethernet and they are 100 pin packaged, going back to aliexpress, we have some boards with this chip (ethernet, 80 pin gpio, 10 timers 4 general purpose can be used to interface encoders, 144 Mhz frequency, ) for 10 euros (version without built-in debugger with debugger 18 euros), I found them very interesting, especially for the cost!!!  I have read before that they are working to port remora to other architectures, I would like to try to port the remora project to these boards, we will see what happens, I leave the links for you to take a look.
Aliexpress Board
Last edit: 3 years 5 months ago by rbobey1989.
The following user(s) said Thank You: Bari
3 years 4 months ago #272669 by scotta
Aliexpress Board
Yes, a really interesting chip with integrated PHY, SDK and very good prices. I just ordered one of these kits (thanks to everyone who contribute to the GoFundMe).
www.aliexpress.com/item/1005005021450761...eLogUid=uaetAnuca0fD
The examples look to have everything we need to port Remora to these boards including In Application Programming (IAP) over Ethernet. First RISC-V board to play with.
The following user(s) said Thank You: Bari, tommylight
3 years 4 months ago #273174 by tuxcnc
I found several EC500 drivers on Aliexpress, from 3 to 6 axes, at various prices ...
Are there any differences in the hardware, or are they just uploading another firmware to demand less or more money?
The second question is, will this controller with Remora firmware serve the lathe encoder?
Time to create page: 0.614 seconds
