3 years 3 months ago #275993 by raf1110
I have tried on linuxcnc to set IP but there was no device seen connected to pc port. I am unsure how to debug via RS232 so far there wasnt anything spitting out in realterm. I have noticed there is no light on lan port on board when connected to pc.
What would be easiest method to test eth connection.
IDE is printing same telnet IP/port as yours in this video
at that time.
After that I don't know how realterm is set to print as on yours although it seem to stay connected to rs232 adaptor.
Let me know if any other info would help I can try to find.
Many thanks
3 years 3 months ago - 3 years 3 months ago #275995 by tuxcnc
There is a solution how to create binary file in MCUXpresso :
Now you can use ST-Link or DAPLink with pyocd (I have three different devices and all work).
Last edit: 3 years 3 months ago by tuxcnc.
3 years 3 months ago - 3 years 3 months ago #276002 by raf1110
I have flashed .bin recommended as per previous post since I have error when compile and flash completed successfully.
Unless that need to be compiled and I have missed something.
Problem is I don't know how to check if board is working
Last edit: 3 years 3 months ago by raf1110.
3 years 3 months ago #276006 by tuxcnc
Do not create equations with many unknowns.
Upload precompiled firmware and configure your computer so that it can see the controller.
Only then compile your own versions of firmware.
I used github.com/scottalford75/Remora-RT1052-cpp
I suggest raw.githubusercontent.com/scottalford75/...ora-rt1052-1.1.0.bin , it does work, I tested.
3 years 3 months ago #276016 by raf1110
I have uploaded that same bin but how to test/connect?
Is there a way to see connect via LAN on windows if IP configured ?
I dont have experience but so far I think all went well so far.
3 years 3 months ago #276029 by scotta
You will need to get your LinuxCNC machine Ethernet configured correctly now and first set your IP address to 10.10.10.2 for example.
Then you can test by pinging the controller board
ping 10.10.10.10
The board will respond to the ping requests. You can then move on to installing the remora-nv component and configuring LinuxCNC.
Time to create page: 0.813 seconds
