- Thank you received: 489
Do you have both python2 and python3 installed on the system? Might have to useSorry if I am asking another dumb question here but...
I have flashed an EC500 pwba with Remora-RT1052-cpp-main (as opposed to Remora-RT1052)
I can ping the board & take it out of Estop, but when I try to upload a config file with...
python3 upload_config.py ec500-rt1052.txt
It says no tftpy module found.
Here is the full text of the install & error....
(Sat Jul-29)-(40K in 5 files)-(alex:~/01_install/Remora-RT1052-cpp-main/LinuxCNC)
(12:10:32pm)> pip install tftpy
Collecting tftpy
Downloading files.pythonhosted.org/packages/c1/8f/43...4/tftpy-0.8.2.tar.gz
Building wheels for collected packages: tftpy
Running setup.py bdist_wheel for tftpy ... done
Stored in directory: /home/alex/.cache/pip/wheels/7e/76/31/0b8b0c463d90688eb47f9326beaaf1232aa9f009a8d1843d99
Successfully built tftpy
Installing collected packages: tftpy
Successfully installed tftpy-0.8.2
(12:11:04pm)> python3 upload_config.py ec500-rt1052.txt
File "upload_config.py", line 7, in <module>
import tftpy
ModuleNotFoundError: No module named 'tftpy'
Thanks in advance.
