- Thank you received: 280
Potential All-in-One Single Board Computers
- cakeslob
3 years 5 months ago #271139
by cakeslob
Replied by cakeslob on topic Potential All-in-One Single Board Computers
the only thing that is noob friendly and works is the raspberry pi with premade linuxcnc image. not exactly an all in one though. everything else is so fucking hard, all day, every day.
- Bari
- Thank you received: 234
3 years 5 months ago - 3 years 5 months ago #271197
by Bari
Replied by Bari on topic Potential All-in-One Single Board Computers
Use a x86/amd64 PC. This thread was for devs and not for noobs.
Noobs should be looking into this thread forum.linuxcnc.org/18-computer/39371-res...or-use-with-linuxcnc
Last edit: 3 years 5 months ago by Bari.
- buzzFab
- Thank you received: 7
3 years 5 months ago #271267
by buzzFab
Replied by buzzFab on topic Potential All-in-One Single Board Computers
I order one of these the other day, I'll add it to your list of potential boards.
I went with the 16gb/256gb variant
NanoPC-T6
www.friendlyelec.com/index.php?route=pro...oduct&product_id=292
[url] www.rock-chips.com/uploads/pdf/2022.8.26...rief%20Datasheet.pdf [/url]
RK3588
4x ARM Cortex-A76(up to 2.4GHz)
4x Cortex-A55 CPU (up to 1.8GHz)
3x Cortex M0
Mali-G610 GPU
4GB/8GB/16GB LPDDR4X at 2133MHz
32GB/64GB/256GB eMMC
I really just picked it up for the 2x 2.5G Ethernet ports so I can use one for EtherCat devices and the 12v input so I can embed it in my control box and use an existing DIN mounted Meanwell PSU. I also paid for the optional M.2 WiFi Card (8822CE) but I don't think I will need it with dual RJ45.
NanoPC-T6
RK3588
3x Cortex M0
Mali-G610 GPU
The following user(s) said Thank You: Bari
- buzzFab
3 years 5 months ago #271616
by buzzFab
Orange Pi 5 Plus with 16gb ram is available from aliexpress as of today
www.aliexpress.com/item/1005005585029938.html
www.aliexpress.us/item/3256805375595121.html
www.aliexpress.com/item/1005005572414487.htm
This is also a rk3588 SBC similar to the nanopc-t6 i posted above but with no integrated eMMc
I ordered one of these as well
The following user(s) said Thank You: Bari, royka
- royka
- Thank you received: 135
3 years 5 months ago #271767
by royka
Replied by royka on topic Potential All-in-One Single Board Computers
Ordered one too to replace the rk3588s which I'm going to use for LinuxCNC. I'll use it with a Mesa card.
Guglielmi has made a software stepgen driver for this board.
His latency test shows it's a very good all-in one candidate:
forum.linuxcnc.org/18-computer/48079-can...cnc?start=170#271679
- buzzFab
3 years 5 months ago #271791
by buzzFab
I thought the driver Guglielmi was working on was for the OPi5 which has RK3588S
Are you talking about the OPi5 Plus which has a RK3358?Ordered one too to replace the rk3588s which I'm going to use for LinuxCNC. I'll use it with a Mesa card.
