Can the OPI5 be Configured to Run LCNC?
3 years 7 months ago - 3 years 7 months ago #267893 by rodw
Replied by rodw on topic Can the OPI5 be Configured to Run LCNC?
Its meant to be possible to build a preempt_rt system with the Armbian build environment but it is broken. One of the Armbian developers has been helping me with the Odorid N2+ and has forked and possibly fixed the environment.
I can’t guarantee that this will work but you guys with the OPI might be able to join in here as my friend Leo is working on the sunxi chip but the OPI 5 is on a Rockchip
But try this on a host PC running a VM or linux debian or ubuntu.
git clone https://github.com/The-going/armbian-build -b pbs-master
Build the userpatches folder and set up the build environment. The settings here are not important, we just need to set up the environment, don’t try and build an image or add a GUI as it will take forever.
cd armbian-build ./compile.sh EXPERT=”yes”
Select EDGE, Debian Bookworm, build the kernel. It should show up in /output/debs
Now copy the attached .config file into the userpatches folder which has been created. (remove the .txt suffix)
Now lets try and build a minimal cli image. This is a 3 step process. Only proceed to the next step if things don’t fail
./compile.sh NAME BUILD_ONLY="default" ./compile.sh NAME BUILD_ONLY="kernel" ./compile.sh NAME BUILD_ONLY="bootstrap"
There is a high probability that you will need to add patches etc to build PREEMPT_RT.
If this works by some fluke, you will have an .img file under /output/images
Use Balena etcher to burn it to an SD card. Don’t use a HDD or eMMC.
Boot the SD card on your OPI5 and cross your fingers.
After a few questions, you should end up with a system with a text only cli as root.
Check that you have preempt_rt
uname -v
If you do get this far, we need to check that we truly have a RT kernel as sometimes I had this but RT was not there. Install the Real Time tests.
apt install rt-tests cyclictest -t -p80 -i10000 (must run as root or sudo)
The numbers should be bouncing around, not static. This is another latency test and should give similar results to the linuxcnc tools
Ok if you got this far, we need a graphical environment and linuxcnc!
apt install task-xfce-desktop firefox-esr linuxcnc-uspace linuxcnc-uspace-dev mesaflash geany
Reboot and you should be able to login to Debian Bookworm.
So if this worked, time to play with isolcpus. This is done by adding an extra line to boot/armbianEnv.txt
sudo geany /boot/armbianEnv.txt
You might need to experiment here. On my 6 core device, I added isolcpus=2,3,4,5 to get best results.
You have 8 cores
At the end add:
extraargs=isolcpus=2,3,4,5,6,7
If the system hangs, you can place the SD card back into your host device, open as root and edit the file. If you have altered your isolcpus, you need to reflect that in cyclictest parameters. Eg
sudo cyclictest -a 2-5 -t -p80 -i10000
Now if you get this far I will be seriously amazed…. And you will need to roll up your sleeves to debug the process.
Last edit: 3 years 7 months ago by rodw.
3 years 7 months ago #267903 by Guglielmi
Replied by Guglielmi on topic Can the OPI5 be Configured to Run LCNC?
Thanks a lot rodw.
I understand to overall flow but honestly it's hard to follow due to lack of knowledge my side.
I never give up.. I have patient, so.. let's go!
I don't wat to stress you too much but I need your help to reach the goal.. do you have time&patient?
In case, I'm open to share the final result, maybe a image for Orange PI 5 with LinuxCNC installed. The board is really promising by specs.
Just for your info, I have a working RPI4 on my cnc, I'm happy, so I don't have really pressure on close this project.
Now.. some basic questions:
1) "the going armbian build" means the main branch of armbian? I found this documentations, can I follow this?  Buinding Armbian
I will mix your suggestions with these instructions..
2) RT Patch: I did many tenetatives already following this instruction:  Patch RT
should I do the same? I tried with version 5.10.176, 5.10.109.. the orginal version of Orange PI 5 is 5.10.110. In this case, with patch should I apply for armbian main branch?
In meanwhile, I will start the first tentative..
Andrea
3 years 7 months ago - 3 years 7 months ago #267946 by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
The Rockchip kernel is there own creation, it's a mess, so impossible to patch with the rt patches without manually edit most of them.
The mainline kernel does not have the opi-5 dtb yet and a lot still doesn't work.
gitlab.collabora.com/hardware-enablement...n/mainline-status.md
I've tried quick to make rt kernel work with RebornOS but did not succeed. RebornOS couldn't read the initramfs, using the original one didn't work. It is possible to edit it but I found out that RebornOS has Panfork installed by default and this doesn't work with the rt kernel because of a config option and there is no source to recompile. So too much hassle to try.
I've installed the image with rt kernel and compiled LinuxCNC. Even without isolating CPU's the latency is under 25us while opening a browser watch YouTube and glxgears. From my previous experience isolating cpu 5 and 7 will bring it a lot further down, isolating more won't do a lot and makes the system as slow as the rpi4.
The only downside is there is no video hw acceleration, but it still does ok without. If you would like to try I could upload an image.
Last edit: 3 years 7 months ago by royka.
The following user(s) said Thank You: Guglielmi
3 years 7 months ago #267947 by rodw
Thanks a lot rodw.
2) RT Patch: I did many tenetatives already following this instruction: [/url] Patch RT
Andrea
I gave you instructions. Don't follow any other path.
You may follow the official Armbian build instructions to fill in the gaps on the first initial build only.
This build includes a flow in the config file I have provided to build the preempt-rt kernel so do not try anything else...
And yes Royka, the Armbian kernels ar flawed, this may be too but until somebody tries it we will not know...
3 years 7 months ago #267951 by Guglielmi
Yes royka, if you can, I will appreciate a lot.. maybe you are right I't enough without RT..
3 years 7 months ago - 3 years 7 months ago #267952 by Guglielmi
Thanks rodw,
yesterday I started to understand better trying.. so now I'm little bit less lost.
Even Royka will send me his work, I will continue to try. Using the repo you suggested, compiling it I get an error:
[ error ] ERROR in function compile_uboot [ cli/cli-entrypoint.sh:109 -> main/build-tasks.sh:196 -> main/build-tasks.sh:47 -> compilation/uboot.sh:132 -> logging/traps.sh:0 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated
I try again with main branch where I was able to build yesterday and also find Bookworm, not present in your repo.
I will keep you informed
Two specific question:
1. Should I download the last patch (e.g. 5.10.176) or the one more close to the version I have (5.0.109 I guess..)?
2. Do you confirm the patch should be placed after the compile process? I'm asking because I tried to place before and in the menu to define the configuration I can see FULLY PREEMPT, thing not visible when the patch is not there. Following your list, I will apply it later on in combination with your config file.. right?
Last edit: 3 years 7 months ago by Guglielmi.
Time to create page: 0.224 seconds
