Can the OPI5 be Configured to Run LCNC?
3 years 6 months ago - 3 years 6 months ago #268517 by Guglielmi
Replied by Guglielmi on topic Can the OPI5 be Configured to Run LCNC?
Ok, my side seems something doesn't work properly..
What I tried:
VirtualBox VM Ubuntu Desktop 22.04
1) git clone --depth=1 --branch=main github.com/armbian/build
2) paste files you shared into kernel and source respecting the path. Files replaced existing copies
3) sudo chmod 777 -R build
4) cd build
5) ./compile.sh
6) select "orangepi5" as board, debian with desktop, legacy, gnome.. finally it fails after a while.
I got the error:
Error 23 occurred in main shell (log attached)
I tried to build a default repo without overwrite files in config, and it arrives at the end correclty.
What I miss?
Last edit: 3 years 6 months ago by Guglielmi.
3 years 6 months ago #268520 by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
I didn't make a full image yet, only the kernel. You could do the same btw, just install the latest image, then install the kernel debs you've created in ~/build/output/debs/
It didn't create the image at all or just that error?
If it's only that error you could cp the kernel to Image.
Not sure if the error is because it tries to make a symlink on a fat partition or it's because it tries to link to the "original" kernel name.
3 years 6 months ago - 3 years 6 months ago #268524 by royka
I see it also got some errors with downloading from ghcr.io, not sure if this caused the error at the end.
Perhaps the old branch will work better.
git clone --branch master https://github.com/armbian/build.git
The new main branch is still heavy in development.
If you only want to build the kernel you could with the old branch (master) use:
./compile.sh BUILD_ONLY=kernel KERNEL_CONFIGURE=yes BOARD=orangepi5 BRANCH=legacy
Last edit: 3 years 6 months ago by royka.
3 years 6 months ago #268537 by Guglielmi
Even worst..
drivers/net/wireless/Kconfig:55: can't open file "drivers/net/wireless/rtl8811cu/Kconfig"
make[1]: *** [scripts/kconfig/Makefile:29: menuconfig] Error 1
make: *** [Makefile:627: menuconfig] Error 2
[ error ] ERROR in function compile_kernel [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:280 -> functions/main/build-tasks.sh:155 -> functions/compilation/kernel.sh:110 -> functions/logging/traps.sh:0 ]
[ error ] Error kernel menuconfig failed
[ o.k. ] Process terminated
I can't arrive to see the menu of the configuration..
3 years 6 months ago #268557 by royka
I always compiled it on the opi5 in Armbian, shall try to build a complete image too.
Did you add a patch or something? Extra drivers needed?
3 years 6 months ago #268559 by Guglielmi
I did not add anything..
Reading on Armbian web page I found to build the image by default first, then build again customizing the configuration..
Well, not sure it makes sense, but now I'm trying this way.
I finished to build a default image, then I applied your files and now I try to build again.
Time to create page: 0.931 seconds
