- Thank you received: 135
Can the OPI5 be Configured to Run LCNC?
- royka
3 years 6 months ago #269091
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Easies way of getting the config files would've been:
git clone github.com/LinuxCNC/linuxcnc.git --branch 2.9
But strange it didn't package the config files, perhaps a config option I didn't see.
The error I could reproduce, when I launch it from terminal it gives the error: DRM_IOCTL_PANFROST_CREATE_BO failed: Cannot allocate memory
I'll look into it
I'll look into it
The following user(s) said Thank You: Guglielmi
- royka
3 years 6 months ago - 3 years 6 months ago #269104
by royka
It's obvious something with the panfork driver, I can't find a solution for that. What does work is using the mali blob driver instead of panfork.
[url] github.com/numbqq/mali-debs/tree/master/.../arm64/Edge2/wayland [/url]
Not sure if this will work after installing panfork mesa, it might be necessary to do a clean install.
With this driver firefox works fine under wayland
"sudo apt install firefox-esr"
To install gnome I'd to remove xfce because this conficted with gdm3 somehow, in case you're getting the same error you could just run this command in a terminal in xfce "sudo apt remove armbian-jammy-desktop-xfce" and install gnome right after it.
With the mali-wayland blob, gnome and firefox installed, LinuxCNC works fine.
Sorry for wasting your time with the wrong advice of installing panfork, should have test it better.
Last edit: 3 years 6 months ago by royka.
- royka
3 years 6 months ago #269119
by royka
If you don't feel to start all over again, you could try the following:
It could be I forgot a package which you should remove/install.
sudo rm /etc/apt/sources.list.d/liujianfeng1994-ubuntu-* && sudo apt update
mkdir restore-mesa && cd restore-mesa
apt download libgbm1=22.2.5-0ubuntu0.1~22.04.1 libglapi-mesa=22.2.5-0ubuntu0.1~22.04.1 libegl-mesa0=22.2.5-0ubuntu0.1~22.04.1 libgbm-dev=22.2.5-0ubuntu0.1~22.04.1 libgl1-mesa-dri=22.2.5-0ubuntu0.1~22.04.1 libglx-mesa0=22.2.5-0ubuntu0.1~22.04.1
sudo dpkg -i --force-all *
sudo apt dist-upgrade
- Guglielmi
- Thank you received: 17
3 years 6 months ago #269125
by Guglielmi
The new driver couldn't be installed.. impossible overwrite "/lib/firmware/mali_csffw.bin" already present in "mali-g610-firmware 1.0.0-2".
What does it mean "to do a clean install"?
can I remove panfork mesa somehow?
Should I start from a new image installation? ..I installed using armbian but I did not choice panfork mesa somewhere..
Replied by Guglielmi on topic Can the OPI5 be Configured to Run LCNC?
no problem, I don't have doubts you are saving me.. without your good job I would already give up.Sorry for wasting your time with the wrong advice of installing panfork, should have test it better.
The following user(s) said Thank You: royka
- Guglielmi
3 years 6 months ago #269130
by Guglielmi
- royka
3 years 6 months ago #269131
by royka
sudo dpkg -i --force-overwrite linux-gpu-mali-wayland_1.1-g6p0-20230406_arm64.deb
The moment you choose to remove panfork with apt remove it will remove about all desktop related parts like gnome/ubuntu.
So to remove I just did it by downloading the non panfork versions and force install them by the commands in my previous post.
To list these you could type:
apt search mesa | grep panfork
After installing the packages in my previous post I've got still 9 packages listed, but it does work.
To replace them is quite simple:
apt show libegl1-mesa -a
This will show all versions of it, then pick the newest version and first try to install it with: sudo apt install libegl1-mesa=22.2.5-0ubuntu0.1~22.04.1
If apt wants to remove a lot of packages you don't want to, you could download it with:
apt download libegl1-mesa=22.2.5-0ubuntu0.1~22.04.1
Then sudo dpkg -i --force-all libegl1-mesa_22.2.5-0ubuntu0.1~22.04.1_arm64.deb
But when you've to force something it's likely you'll have to install more packages the same way, otherwise apt will be annoying (won't install anything)
Time to create page: 0.177 seconds
