- Thank you received: 7
Can the OPI5 be Configured to Run LCNC?
- kanuboy13b
3 years 6 months ago #269193
by kanuboy13b
Replied by kanuboy13b on topic Can the OPI5 be Configured to Run LCNC?
Sorry, I got pulled away from this project so I haven't been able to test anything out. Though I did run into the same issue that Guglielmi was having with no configurations. I am planning to tinker around with it tomorrow though. Just been busy.
- royka
- Thank you received: 135
3 years 6 months ago #269203
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
No problem, my goal was to make it easy to create your own system that you're able to maintain/update yourself. As you could see I made some wrong assumptions why it didn't work for you.
To fix the missing configuration files you could just clone the whole 2.9 branch:
cd ~ && git clone github.com/LinuxCNC/linuxcnc.git --branch 2.9
Or you could use the following link to create/download only the configs directory. The zip file should then be extracted to ~/linuxcnc/configs
[url] download-directory.github.io/?url=https%...tree%2F2.9%2Fconfigs [/url]
If you've installed panfork mesa, it won't start somehow, to remove/replace this you could follow the steps in:
[url] forum.linuxcnc.org/18-computer/48079-can...lcnc?start=80#269119 [/url]
If you still want to have hw acceleration for a smooth UI you could download the driver from:
[url] github.com/numbqq/mali-debs/tree/master/.../arm64/Edge2/wayland [/url]
Install with:
sudo dpkg -i --force-overwrite linux-gpu-mali-wayland_1.1-g6p0-20230406_arm64.deb
Then install a desktop environment with wayland (choose gdm3 when you're asked for it):
sudo apt install gnome
or
sudo apt install ubuntu-desktop
Install with:
or
- Guglielmi
- Thank you received: 17
3 years 6 months ago #269212
by Guglielmi
Replied by Guglielmi on topic Can the OPI5 be Configured to Run LCNC?
Royka, I have now a SD card with linuxCNC working, etc.. however, I found some issue when I tried to use the wifi.. it was correctly configured and working before the patch, now not anymore and I'm not able to add the driver because I found a mess in the kernel modules.
I tried to recreate a new SD from scratch (keeping a part the one working...) and the result is the same, installing heladers deb I got an error and finally, even it works, inside folder /lib/modules/5.10.110-rt-rockchip-rk3588 there is a broken link "build". It points to the folder "/usr/src/linux-headers-5.10.110-rockchip-rk3588" without "rt53"! so it is broken.
I created a new build link but the situation is not changed installing new drivers.
Can you please repeat the last procedure you suggest? Sorry for the question but going back in this loop I have some doubts I'm doing right steps, the dab file with kernel I was able to download from the forum is without "rt53", the link rt53 file is not available any more.. for headers seems correct. So.. the correct last deb file has it "rt53" in the name or not? or.. can you share again both links in a new post? Be patient...... thanks!
- royka
3 years 6 months ago #269222
by royka
Armbian doesn't like local versions.
[url] forum.linuxcnc.org/18-computer/48079-can...lcnc?start=70#268702 [/url]
That's why there were build/install problems, to try to "fix" the installing problems I was editing the initramfs and made a typo "rt".
But the last package of the kernel I'd uploaded I removed the local version so it will build/install normally, so you should have no folder with "5.10.110-rt-rockchip-rk3588" or "5.10.110-rt53-rockchip-rk3588". The headers you would only need if you want to compile a kernel module after the kernel is built.
So you probably would only need to install the kernel with: sudo apt install ./kernel-name.deb
[url] mega.nz/folder/zhwVyJBK#iWqElAfYL21Rn08PmB55DA [/url]
If that doesn't work tell which wifi adapter you use.
btw it should be easy now to create your own image/kernel with that little patch that removes the local version.
The following user(s) said Thank You: Guglielmi
- kanuboy13b
3 years 6 months ago #269407
by kanuboy13b
Well I'm not exactly sure what I am doing wrong. I'm trying to build a fresh image of Armbian using the patches you provided, but I can't get the image to boot. Since I had installed the panfork mesa, I figured instead of going through the process of uninstalling I would just build using the patched files. And once I found out that for some reason or another the VirtualBox install on my Manjaro machine was not working properly I just decided to install Ubuntu as a Dual boot and build directly.
Building I followed the instructions on Armbian's website:
using Git I downloaded the build environment using the following command:
once downloaded I copy and replaced the files from the patched config files and also copied the userpatches directory to the build directory.
ran ./compile.sh to start the build process
I selected "Do not change the kernel configuration" as for some reason if I try to run the kernel configuration menu, it starts to bug out and I can't proceed with the build process.
selected orange pi 5 for the board, legacy for the kernel
jammy for the package base
I attempted both the console interface and desktop environment options for the image, using gnome for the latter.
Everything seems to work fine, images are created, they just won't boot. plug in the board, red light comes on, wait for something to pop up on the screen, and nothing. I have a feeling there might be a setting or option I am missing but not sure what. Is there any additional config edits that need to occur in the boot partition that I am missing? I have yet to try a vanilla build without applying the patches to see if that will boot. but I figured I share my progress first before doing so.
git clone --depth=1 --branch=main https://github.com/armbian/build
- royka
3 years 6 months ago #269411
by royka
It seems you did the steps in the right order, no other steps should be required. To see what happens in the bootloader, the output on the uart pins is very helpful.
I'll see if I could reproduce the same error.
Since hw video decoding doesn't work with the packages from the jammy repo with the mali blob, I'll see if Debian Bookworm will work like rodw suggested.
Time to create page: 0.299 seconds
