- Thank you received: 502
It might be easier to use the docker container, see the documentation in the git repo. github.com/multigcs/riocore/blob/main/DOCKER.mdI get the command line console and it quits out with ctrl+d as you say, but I'm still getting the same issue, I had changed the filename to something other than config.json to suit the machine, so I changed it back to config.json but no dice.
I found the gowin toolchain a major problem to get running on a few systems like a current LTS release of Ubuntu, so I built a docker container for the oss-cad-suite. Meister added one for the gowin toolchain, and one for oss-cad-suite on the pi. I think the pi one should work fine on the pi5 too.I'm trying to get the gowin toolchain up and running on rpi5. It gives me an error when execute making all.
Code:cnc@raspberrypi:~/riocore/Output/TangNano9K_spi_rpi5/Gateware$ make clean rm -rf rio.fs rio.json rio_pnr.json rio.tcl abc.history impl cnc@raspberrypi:~/riocore/Output/TangNano9K_spi_rpi5/Gateware$ make all gw_sh rio.tcl /opt/gowin/IDE/bin/gw_sh: 2: Syntax error: Unterminated quoted string make: *** [Makefile:34: impl/pnr/project.fs] Error 2 cnc@raspberrypi:~/riocore/Output/TangNano9K_spi_rpi5/Gateware$ I see you've already mentioned this error. I downloaded and cloned the dev version and it still doesn't work. Any tips... I see there is another option 'generic_spi'. I will test that on rpi5 too just to get that toolchain working. I don't want to take the TN9 out of the device and program on windows anymore.
Many thanks Zayoo !
i have add the code to the dev branch for testing.
if you want to use it, you can add
[/code]Code:"rpi5": true, to your json config like this: [code]{ "name": "IceShield", "description": "RIO-IceShield on Raspberry PI5", "boardcfg": "IceShield", "protocol": "SPI", "rpi5": true, ....
