- Thank you received: 11
Just checking, I don't mean to offend, but have you tried restarting the computer? Terminals often inherit environment (including path) from processes that spawned them, including login sessions.So I can run gw_sh from anywhere, I also edited my .bashrc to make the PATH permanent.
Here is the terminal text, it is still saying it cant see the gowin path, interesting the first line saying XDG_RUNTIME_DIR is not set, I have no idea what that is but it doesn't sound good...
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
loading config: riocore/configs/TangNano9K/config.json
loading board: /home/gus/riocore/./riocore/boards/TangNano9K/board.json
rm -rf rio.fs rio.json rio_pnr.json rio.tcl abc.history impl
gw_sh rio.tcl
make: gw_sh: No such file or directory
make: *** [Makefile:34: impl/pnr/project.fs] Error 127
loading: riocore/configs/TangNano9K/config.json
loading board setup: TangNano9K
loading toolchain gowin
writing gateware to: Output/TangNano9K/Gateware
!!! gateware changed: needs to be build and flash |||
WARNING: can not found toolchain installation in PATH: gowin (gw_sh)
example: export PATH=$PATH:/opt/gowin/IDE/bin
writing linuxcnc files to: Output/TangNano9K/LinuxCNC
gw_sh rio.tcl
Thank you, I appreciate your patience with my questions!* at the end, the flash select is set to 1 again for safety reasons, as the SPI line is to be used for communication with the FPGA (7 = 1)
Anyone can open a PR with updated documentation!Only thing hire is missing one good in depth help file!
