Hi Olli
Thank you once again for your prompt response to my issue.
I have done a very quick test and at the moment I am over the moon, all the outputs work as they should.
I am using your template for N4D3E16, with exactly your settings.
When I use LinuxCNC it works perfectly, but if I use the test-gui in riocore the outputs work, but i get the following errors in the terminal window.
loading board setup: Tangbob
connection via: UDP
IP: 192.168.10.194
PORT: 2390
WARNING: can not set timeouts: timed out
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 457, resource id: 11699426, major code: 40 (TranslateCoords), minor code: 0
ERROR: modbus CSUM failed [173, 219] != [136, 17]
ERROR: modbus CSUM failed [92, 27] != [136, 17]
ERROR: modbus CSUM failed [60, 136] != [1, 225]
ERROR: modbus CSUM failed [108, 27] != [73, 209]
I will test for a little while longer to see if I can figure out if I have configured something incorrectly.
To use the inputs originally I used the following settings. I cant remember why I broke them into lots of 4, I'm thinking that if I put a "values" as 16 it wouldn't work
"inputs1_4": {
"address": 1,
"type": 3,
"register": 129,
"values": 4,
"is_float": false,
"scale": 1.0,
"unit": "",
"error_values": "",
"format": "d",
"timeout": 100,
"delay": 60,
"direction": "input"
"inputs5_8": {
"address": 1,
"type": 3,
"register": 133,
"values": 4,
"is_float": false,
"scale": 1.0,
"unit": "",
"error_values": "",
"format": "d",
"timeout": 100,
"delay": 60,
"inputs9_12": {
"address": 1,
"type": 3,
"register": 137,
"values": 4,
"is_float": false,
"scale": 1.0,
"unit": "",
"error_values": "",
"format": "d",
"timeout": 100,
"delay": 60,
"inputs13_16": {
"address": 1,
"type": 3,
"register": 140,
"values": 4,
"is_float": false,
"scale": 1.0,
"unit": "",
"error_values": "",
"format": "d",
"timeout": 100,
"delay": 60,
Thanks again.
Andrew
