1 year 7 months ago #323246 by kzali
I tried that but maybe there is an issue with my w5500. Thanks great Cornholio
1 year 7 months ago #323258 by meister
give us the output of the command:
ip address show
1 year 7 months ago #323327 by kzali
My bad
Okay so when I was looking up the schematics and pcb files I realised that I had inserted the Tang nano in the wrong directionimage missing /media/kunena/emoticons/unsure.png,  when I fixed that tand powerd the bob a bright red led light up on the w5500 module and the Lan link was connected to the host,  when I pressed test gui button the select target popped up for udp 192.168.10.194.   pressed ok  and tested wled selecting the 3 boxes lit up the wled on the bob and tested all colors worked like a charm. There was this warning in the terminal (dont know if it is important)  connection via: UDP
IP: 192.168.10.194
PORT: 2390
WARNING: can not set timeouts: timed out
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 10551690, major code: 40 (TranslateCoords), minor code: 0
RIO-TestGui is great. Next step power the 5axis bob and setup some test hardware and usb power the China Bob. Great work Olly. Me super excited. Thank you Robert and Oliver for your quick responses.
Cheers
Kam
The following user(s) said Thank You: meister, unknown
1 year 7 months ago #323336 by meister
Hi Kam,
the warning and BadWindow stuff can be ignored
Cheers
Olli
1 year 7 months ago #323348 by unknown
hahaha Kam
It's intriguing how people will try to point the finger at the hardware or software rather than themselves......Yes I've been guilty of that myself, but I'm less likely to do that now, at least I hope.
1 year 7 months ago - 1 year 7 months ago #323456 by royka
Just to let you know, that the SPI connection (generic) also works with the Orange Pi 5 and the TangNano9k.
Great work meister!
By the way I think that supporting Mesa boards would be beneficial for many, since it's much easier to adjust the functions of the pins.
Last edit: 1 year 7 months ago by royka.
