Remora for RP2040
07 Jul 2024 06:59 #304576 by Baazengr
Replied by Baazengr on topic Remora for RP2040
I am also having this issue. The controller hangs when i use outputs.
Any luck finding a solution?
10 Jul 2024 05:17 #304799 by Limo
Replied by Limo on topic Remora for RP2040
Hello,
I have no idea if it is the right place to ask, but I have a question regarding remora.
Is it possible to drive a Spindle with a step/dir interface in remora?
12 Jul 2024 06:45 - 12 Jul 2024 06:49 #304980 by fklco
Replied by fklco on topic Remora for RP2040
"I'll need to update the firmware with the absolute position feedback and spike filter like we've done in the NVEM / EC300 / EC500 firmware and in the dev version of the original Remora. Solves those following error spikes. "
Hallo Scotta, did you have it time to update the firmware?
Thanks!
Last edit: 12 Jul 2024 06:49 by fklco.
  • scotta
  • Platinum Member
  • Platinum Member
13 Jul 2024 20:09 #305115 by scotta
Replied by scotta on topic Remora for RP2040
Hi, I have been looking at this and cannot replicate the issue. Please share your config file as all the combinations I have tried work ok for me.
  • scotta
  • Platinum Member
  • Platinum Member
20 Jul 2024 18:42 #305736 by scotta
Ok, some more investigation. Using the publish uf2 file and your config I confirm the issue. I've recompiled my master branch which had some unpublished clean-ups (debug info) from the ping-pong buffer implementation, and your config happily loads and runs.
I've also added a firmware folder to the repo to make finding the uf2 file easier.
github.com/scottalford75/Remora-RP2040-W...ora-rp2040-1.0.1.uf2
I'm working on making the RP2040 version compatible with the latest LinuxCNC Remora ethernet component, but currently this version still uses the legacy remora-nv component.
  • scotta
  • Platinum Member
  • Platinum Member
20 Jul 2024 19:34 - 20 Jul 2024 19:35 #305739 by scotta
I've migrated the Remora for RP2040 to now use the Remora-eth-3.0 component.
Download the latest firmware
github.com/scottalford75/Remora-RP2040-W5500/tree/main/firmware
Upload the remora-rp2040-2.0.0.uf2 file to your pico.
To configure the linuxcnc hal module and configs use the files here:
Hal Files (run halcompile on these)
github.com/scottalford75/Remora-RT1052-c...omponents/Remora-eth
and the configs:
github.com/scottalford75/Remora-RP2040-W...onfigs/remora-rp2040
Last edit: 20 Jul 2024 19:35 by scotta. Reason: typo
The following user(s) said Thank You: Baazengr, avive
29 Jul 2024 02:19 #306310 by avive
Replied by avive on topic Remora for RP2040
Is it possible to work with rp2040 via uart instead of Ethernet? Is the bandwidth and response time enough? I'm considering a variant of sbc on Intel n100 with rp2040.
  • scotta
  • Platinum Member
  • Platinum Member
30 Jul 2024 15:50 #306440 by scotta
No, even at high baud rates, serial is just not fast enough.
The following user(s) said Thank You: avive
04 Aug 2024 14:03 - 04 Aug 2024 14:05 #306940 by Bari
Replied by Bari on topic Remora for RP2040
Shipping soon:
linuxgizmos.com/w55rp20-evb-pico-integra...ntroller-and-rp2040/
W55RP20-EVB-PICO: Integrating W5500 TCP/IP Controller and RP2040
Last edit: 04 Aug 2024 14:05 by Bari.
09 Aug 2024 14:07 - 09 Aug 2024 14:11 #307379 by Bari
$5 Raspberry Pi Pico 2 with RP2350 Microcontroller
linuxgizmos.com/introducing-the-5-raspbe...350-microcontroller/
Now we need them to combine the newer 2350 with the W5500.
Last edit: 09 Aug 2024 14:11 by Bari.
Time to create page: 0.348 seconds
